Spyder/Cayman R Discussions about the 987 Spyder/Cayman R (2011-2012)
2006-2008 Cayman Track Mods
Old 10-05-2014, 06:57 PM
ja78911sc
ja78911sc's Avatar
Default 2006-2008 Cayman Track Mods
Trying to get a rough estimate on the expense for the following mods:
Deep sump oil pan
Under drive pulley
Insulated power steering lines
Additional oil cooling
Old 10-05-2014, 08:23 PM
Bill Lehman
Bill Lehman's Avatar
For starters look here http://www.mantissport.ca/ . I never heard of insulated P/S lines, but a P/S cooler is a good idea if running R-comp tires and a fast pace. Adding a 3rd radiator helps oil and water temp. Mine cost about $350 plus installation. I do most of my own work so don't know installation costs.
Old 10-10-2014, 10:27 PM
KS-CS
KS-CS's Avatar
Check out LN Engineering
Old 10-10-2014, 11:54 PM
Frank 993 C4S
Frank 993 C4S's Avatar
+1
The 3rd radiator is actually not required but it is a relatively cheap mod that will help you with cooling and longevity.
The Bodymotion deep sump oil pan is probably the best there is - it is also the most expensive. You might also look into a trans cooler.
Old 10-11-2014, 08:15 AM
Hi-Arc
Hi-Arc's Avatar
Group buy currently being offered on the Mantis Deep sump oil pans. This is the newly designed version. 20% off on Planet 9
Old 10-11-2014, 10:32 AM
KS-CS
KS-CS's Avatar
Here's the link to group buy: http://www.planet-9.com/news-items/1...group-buy.html
Quick Reply: 2006-2008 Cayman Track Mods
