New Boxster Spyder best handling P-Car ever?
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Aside from the Spyders weight reduction and lowered ride height, I am curious what the difference in spring rates are and if there is a difference in sway bar size in the Spyder vs the 987 for the handling to be that superior. Has anyone come across these specs?
There was an article in Excellence recently (who had the same sentiment as C&D regarding handling) comparing the Spyder to the Cayman S on track.
The Cayman has less body flex, but is ~200lbs. heavier, with most of that up high. That weight reduction and lowered center of gravity, along with wider track, allows for a unique suspension set-up (I don't know the specifics) and lower spec'd tire pressures. Which gives it an unusual combination of very little body roll, as well as compliance for both tire contact and ride comfort, resulting in stellar grip.
20mm lower than PASM equipped Boxster
increased spring stiffness 10% front and 30% rear
stiffer front anti-roll bar, same rear
changes to the damping, reduced rebound and increased compression
doesn't mention anything about tire pressures but I do believe they were revised.
I am mustering up as much restraint as possible right now.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Need to wait about a year before I can afford to buy one and keep the 928.
Stock for stock, no doubt the newer cars are able to function as phenomenal road cars while offering pretty unbelievable handling. But handling/grip is so tire dependent. Case in point--what's "better" handling head-to-head at the track, a Cayman S with oversized street rubber or my 125K '97 C4S with some 6 year old Hoosiers and the dead original shocks and a ~180lb passenger? No problem running ~2:08 at Thunderhill on the full track for both cars. Was actually quite a "race" for a whole session. Did I need to be spot on? No doubt. Does my car smoothly soak up the bumps on the ride home? For the most part. But I've got a ~$30K car to the Cayman S at $55-60-70K.
Now if you want to get into basic suspension mods, on equal tires, my '95 993 can comfortably stay ahead of a stock 997.1 GT3RS. Not on acceleration. But that's ~2:01 laps, again Thunderhill.
In addition to the lower tire pressures on the Spyder, it also has wider wheels with different offsets for wider track, and different alignment spec's with more negative camber.
Is there anyone that autocrosses a GT3RS? I don't think that car would be the best tool for the job. I would think a Spyder would kill a GT3RS in an autocross?
Pirelli Trofeo on Spyder running at 33psi hot (27 cold) w/nitrogen, Pirelli Corsa System on RS.
Correct.
And it needs way more camber than stock if you are going to maximize grip and tire wear. My front seems good at -2.5 but rear was not enough at -1.7 and am bumping that up to -2.2 this morning.
You need GT3 LCA's to get that front camber, no parts needed to get the rear camber.
Track day tomorrow, will post results of new spec.
I think the car is way up there... Our shop car is entered into the Grassroots UTCC in July, excited to see what times we turn.
No turbo at that point, just suspension tuning.
A great mid engine car will usually beat a front engine or even a rear engine car with the same driver. They need to give their mid engine chassis cars a GT engine - that would be something.
Is the Spyder the best handling Porsche ever? I think so. Does it handle better than my GT3RS? Yes.
In addition to C&D, the following article reaches the same conclusion: http://jalopnik.com/5549796/2011-por...er-first-drive
Excellence mag summed up the suspension mods quite well . . . kudos to Maurice van de Weerd for delivering the goods. http://www.excellence-mag.com/issues...s/spyder-sense
Yes*
*Based on my experiences, I think so. But when you talk about "best," things can get murky. Carrera GT is brilliant and more rewarding, but also far friskier/riskier. That said, I've driven some PHENOMENAL-handling and deeply, deeply rewarding 911s over the years (some factory, some tuned). But if the question is handling pure and simple, I think the Boxster Spyder just may be the one. Which just gave me an idea for a story...
Thanks!
pete
P.S. And, yes, the Cayman might have a stiffer structure, but its suspension tuning is nowhere near as good for purpose as the Spyder. Now, a Cayman with Spyder-style setup....
Thanks!
pete
