RS Door Panel Removal [VIDEO]
Hey everyone,
I really didn't see this documented too well online so I wanted to pay it forward for the next guy. Hope this helps someone out. Cheers! |
Really nice job. Thanks for the helpful video
Originally Posted by DasCayman
(Post 19372717)
Hey everyone,
I really didn't see this documented too well online so I wanted to pay it forward for the next guy. Hope this helps someone out. Cheers! Here is the correct way: https://cimg2.ibsrv.net/gimg/rennlis...a58e123339.png https://cimg5.ibsrv.net/gimg/rennlis...55449274d5.png https://cimg3.ibsrv.net/gimg/rennlis...a310233997.png Similar plug removal tools are readily available... |
Originally Posted by Kuro Neko
(Post 19372788)
Except, it is wrong!
Here is the correct way: https://cimg2.ibsrv.net/gimg/rennlis...a58e123339.png https://cimg5.ibsrv.net/gimg/rennlis...55449274d5.png https://cimg3.ibsrv.net/gimg/rennlis...a310233997.png Similar plug removal tools are readily available... I didn’t want the next person to bend their metal bracket because it will require you to remove that interior metal cover and bend it back in place. cheers |
(Post 19372717)
Hey everyone,
I really didn't see this documented too well online so I wanted to pay it forward for the next guy. Hope this helps someone out. Cheers! https://youtu.be/Awg6eMhLqjI Thanks again. JP |
Nice job, thank you for putting this together.
(Post 19372804)
Thanks for the response. This is what I originally did and there was a lot of stress on the interior metal door panel where the foam door panel rests / hangs on. It’s like a French cleat. I ended up bending this interior metal trim which I why I recommend popping the bottom of the panel off first and then sliding the cosmetic door panel up and off the metal cleat. Similar fashion / methodology to the triangle door mirror trim piece.
I didn’t want the next person to bend their metal bracket because it will require you to remove that interior metal cover and bend it back in place. cheers The process is to unlock the plugs first (they have two positions), with the correct tool, then the door panel lifts up and free easily. As per the instruction sheet above; just follow the A, B, C sequence. There's numerous video and similar on the internet describing the correct process, as pulling on the top first would likely damage the fittings, yes. |
