987.2 Spyder Sunshade/Weather Protector Usage
Greetings,
Now in the third week of owning my Spyder and really enjoying the car. I was curious how some of you are using the Sunshade and Weather Protector- separately (in the case of the former) and together:
1- What is the max speed with both Sunshade and Weather Protector (I know what the manual says) that you have gone? Any issues?
2- What is the max speed with just the Sunshade? The manual doesn't distinguish top speed with or w/o the Weather Protector? Should there be a difference due to drag changes?
3- When just the Sunshade installed, do you pull out the windscreens within each headrest or the center window between the headrests?
4- I've noted that with the Sunshade and Weather Protector installed, the Passenger window seals perfectly (in and out) but the Driver's side does not the further towards the back of the window (towards the rear). Can this be adjusted?
Thanks,
G.
Thanks,
G.
1) I have a speedwarning set at 205 for this purpose
2) I do not notice any difference between the two
3) I usually have the window out unless it is to cold or wet. Taking the screens out doesn’t make a big difference. I prefer the look with the screens.
4) are you sure the top is fitted correctly? Both the end caps in place op the top brace?
the window can be adjusted but I would do it with the backpiece installed as the window rubs the rubbers at the back.
enjoy your spyder!
enjoy your spyder!
geoorlando (08-05-2021)
At the track, I have had the top visibly lift at speed. The seals on the windows open due to the lifting and there is a marked change of pressure.
With the rear screen off, on the road, at higher speeds, the top seems to vibrate more at the back than with the screen on.
Note it’s the total wind speed that matters. Travelling at lower road speeds in high head winds or side winds brings on the effect. It’s not dangerous, just noticeable.
