Rattle from inside both doors
Hi all,
On my recently new to me Spyder there is a tinny rattle within each of the doors that is basically constant unless the road is like glass. I have seen a post about how it might be from the seatbelt tower (or whatever it is called) but it's not that. It sounds like it could be the latch where the door closes, but I was wondering if this is common issue/rattle? Search didn't turn up much other than the previously noted comment.
Many thanks,
-Adam
Many thanks,
-Adam
Hi all,
Many thanks,
-Adam
Many thanks,
-Adam
Thanks for this. I’ll check that when my garage temps cool down too
Unfortunately that doesn't appear to be it. It certainly sounds like it's coming from inside the doors. Once it cools down I'll remove the cards and see what's going on.
Sorry that it wasn't your cause. I found my tinkling rattle easy to "fix" with a duct tape "brassier" for the noisy nipple (no, I am not in the pronfilm trade). A small square of silver duct tape applied to the noise maker keeps it from rattling within the stud. The fix is invisible unless the boot lid is up. Of course I will have to remove the bras whenever I need to use those particular studs to mount the rear top panel on the car, and the duct tape may not have much of a lifetime. But it is trivially quick to reapply the duct tape pieces as needed. For the time being, the tinkling rattle on rough roads is gone.
