Toyo RR heat-cycling?
TireRack offers to heat-cycle them before shipping.
What do you choose?
Any other/better source for these tires?
What do you choose?
More generally, does heat-cycling (vs not) at all affect performance in the first few sessions or does it only affect longevity (performance/grip after 10+ sessions or heat-cycles)?
Hopefully one of the more experienced racers will chime in, but I believe "proper" heat cycling effects the longevity and not the initial performance.
I haven't watched this yet, but motorsportreg had a seminar on R comps.
According to Jeff Spears at Hoosier, machine heat cycling is a waste of money. In addition to heat, the tires need to be worked/stretched on a track environment to be properly heat cycled. Also, letting them sit for a week or two after cycling is better than 24 hrs.
I can't comment on the RR's, I've not run with and without cycling, but in general, heat cycling is for longevity as has already been posted. If you are just worried about qualifying, just scrub the tires in for a few laps before the qual session.
In terms of longevity, what is typically expected from a set of RR's for racing at podium pace?
FIRST WEEKEND (for new sticker tires)
Qualifying session
Race 1
Race 2
(Enduro?)
SECOND WEEKEND
Practice 1
Practice 2
...then scrap? And start with new stickers for Qualifying again?
Could heat-cycling make them useful (still competitive) beyond this? Maybe Qual and both races on the SECOND weekend on the same set? Or are they basically scrap after only 5 heat cycles?
Qualifying session
Race 1
Race 2
(Enduro?)
SECOND WEEKEND
Practice 1
Practice 2
Basic Site Sponsor
Basic Site Sponsor
You can always heat cycle them in the first practice if desired then let them sit overnight.
Its really not critical, honestly.
I bolt a set of stickers on for qualifying/final practice and run them the rest of the weekend, including the enduro. They then get used for the first two practices the following weekend. After that they are getting worn down and/or starting to fall off so we scrap them.
We budget for one set of tires per weekend.
Ok, case closed! Thx everyone for your inputs!
What Todd said.
FWIW. I get my tires from Tires Direct. $100 off a set plus FREE shipping. ($915)
http://www.tiresdirect.net/Product.a...CategoryId=968
What Todd said.
I'm in....
I get mine from Woodman at the track. I just try not to get them too hot on the first session (no sliding). I've found that usage determines longevity more then heat cycling
