Spec Boxsters For info sharing on this exciting new class
SPBDA meetings
Old Apr 3, 2017 | 06:43 PM
  #151
toddlamb's Avatar
toddlamb
Former Vendor
We've gone far down this path with Spec Miata. We now rebuild transmissions for $1200, and the parts are a fraction of the cost of Porsche parts. They still don't last as long as a junkyard SPB tranny due to weak gears and over grippy tires.
Not sure we'd want to get into $1200 transmissions let alone $3500 rebuilt transmissions. I'm pretty happy carrying a $850 spare trans in the trailer for each car.
Old Apr 3, 2017 | 06:47 PM
  #152
FeuerRacing's Avatar
FeuerRacing
The broken transmission concern is why I pay for track support as I can do everything myself. I suppose I just need to get comfortable changing them.
But keep your mouth shut on my transmission change to find 0.5 secs on the straight.
Old Apr 3, 2017 | 06:53 PM
  #153
toddlamb's Avatar
toddlamb
Former Vendor
I won't tell a soul! lol
Old Apr 4, 2017 | 11:53 PM
  #154
ace37's Avatar
ace37
Got a few questions about removing parts and they may just be a matter of interpreting the rules:
1. I suspect this could be interpreted to be "interior," but I wasn't sure. Can I gut the left and right side mirror electronics and motors? And is there any recommended off the shelf lightweight manual system to mount the mirrors to?
2. Which spot welded pieces can be removed from the floor? Thinking of the seat mount floor pieces and a few little metal brackets, the little one behind the e brake and the piece tacked on in the passenger footwell near the passenger's right foot. I assume at least taller drivers would be allowed to drop their seats if necessary but I don't see it in the rules. Not planning to touch these now but perhaps when the cage goes in.
3. Does 7A, "Factory dashboard instrument pod must remain intact," mean the instrument panel must remain intact or that the dashboard has to remain intact and the instrument pod has to be there too? I would expect this to mean the same thing as "the instrument pod on the factory dashboard must remain intact" the way it's written. I don't see any cars with custom dashboards though so I assume there's a word missing and it should read something like "Factory dashboard and instrument pod must remain intact." But if I can do a custom dash I'd like to explore it.
Old Apr 5, 2017 | 08:36 AM
  #155
bkovac's Avatar
bkovac
I have the seat frame removed to lower the seat. I would do that 1st and mock my seat. The reason is is that the left side of your seat may hit the driver side impact tubing. I have witnessed this with others when they perform this after the fact. i'm only 6' but i now have over 6" of head room.
Old Apr 5, 2017 | 10:38 AM
  #156
toddlamb's Avatar
toddlamb
Former Vendor
You can remove the mirror wiring but the rest should remain.
No need to remove anything from the floor and it isn't allowed in the rules (despite some arguments for safety allowing any modification). I'm 6'3" and have plenty of headroom without removing floor mounts.
The IP/dash/gauges should remain in place. You can mount something like an AIM dash (we sell mounts) directly in front of the gauge cluster if desired, but you don't need a custom dash.
Focus on what's needed to be competitive, and more often than not it's the driver, not the car, that needs special parts
Old Apr 5, 2017 | 03:11 PM
  #157
ace37's Avatar
ace37
Thanks guys! Right now part of what I'm trying to do is just learn how racers interpret these rules so I can properly interpret when I'm still not clear after reading them a few times and googling a bit.
Yeah, I had googled a bit and it appeared some people remove them and others leave them. While I wasn't expecting it to be unconditionally legal I also didn't think it a big deal and figured waivers should be easy to get if that's how it was done. Tall guys, grandfathered cars from those guys, roll cage issues, etc. I expected the floor would need to be modified to some degree to accept a race seat regardless, so I figured this was an area to just ask what's the norm.
The seat hitting the cage is an interesting point. I'll definitely do a test fit. It's looking like I'll have my seat before the cage so I should be able to avoid the issue. I'm 6'1" so I should be able to find enough headroom with the frame in place. I understand wanting to maximize it though.
The mirrors seemed a bit opaque to me so I wanted to hear what others were doing and just do that - if everyone guts them great and if they are left alone that's great too. Not sure there's any weight savings to be had but it's easy to ask when I'm taking things apart. I'll just leave them.
And on the floor, it sounds like that's why it was happening - safety arguments. Not sure I agree with it in the general case but I could see a lot of valid exceptions and it really wouldn't impact the racing. But that helps me understand what I've been observing and make sense of it. At this point I don't expect to pull them when the cage goes in as I should be able to get enough headroom with them in place. It might attract scrutiny and I don't see much advantage - the floor is a good place for ballast anyway.
What you're saying on the dash is what I was concluding from looking at photos of built cars while reading the rules. I think the wording in the rules is a bit poor regarding the dashboard itself but quite clear elsewhere. I didn't think a custom dash would save any weight but thought it might be an easy project and look nice in the car. Since everyone is doing it the same way though, maybe I'm the only one reading the rules that way. In the long run I was thinking to put in a nice AIM system over the instrument panel like others have done but I've got a lot of fundamentals I need to get worked out first. Like spec suspension and a cage.
I wasn't expecting any meaningful competitive advantage could be gained from these fairly trivial things - I'm just having fun in the garage building a race car. But I figure if I'm taking things out and fiddling with it I may as well do it all right the first time. And if the next guy has the same questions he can find this thread using google.
_______
I also didn't see it explicitly, but I've assumed the windshield washer assembly falls under the interior or trunk rules and is fair game to remove so I was going to pull that at some point.
Thanks for the explanations! I'm enjoying my little Boxster race car project and looking forward to joining the class.
Old Apr 6, 2017 | 04:01 PM
  #158
Gary R.'s Avatar
Gary R.
Originally Posted by FeuerRacing
I carry 4 spare transmissions in my trailer and I'd like to save the weight in my trailer and my pocketbook.
It's going to be a problem long-term that will hurt the class because of the costs (replacement and labor).
Now I know where to go begging if mine blows up again!
Old Apr 6, 2017 | 04:09 PM
  #159
Gary R.'s Avatar
Gary R.
How are you going to wash your windshield during a race??
Old Apr 7, 2017 | 01:35 PM
  #160
tgsmith4845's Avatar
tgsmith4845
Mark Foley and Brad Roberts were working on something that they thought was the problem with the transmission. A hollow drive shaft or something like that that was flexing and overstressing the gears. They were wanting to beef it up but keep the hole down the middle for fluid transfer. I'm probably not saying it correctly but would love to hear from them on their prognosis and what it would take to invest to test the theory. I carry 4 spare transmissions in my trailer and I'd like to save the weight in my trailer and my pocketbook.
Checking with Mark and Brad now. Brad's busy working the big leagues now, and Mark with his Cayman build. Will see what the status is on trans strengthening.
Old Apr 20, 2017 | 03:20 AM
  #161
ace37's Avatar
ace37
As a new builder I would recommend rules clarifications on:
1. Radiator Fan Removal - Recommend rule 2G be changed to make fan removal legal since it seems to be accepted and common practice.
Originally Posted by SPB Rule 2G
An additional radiator in the center of the grill area is allowed; stock radiators must be retained.
Originally Posted by SPB Recommended Rule 2G
An additional radiator in the center of the grill area is allowed; stock radiators must be retained. Removal of radiator fans is allowed.
2. Floor Seat Support Bracket Removal (spot welded to floor) - If illegal, clarify in rule 7B and consider offering waivers as this is hard to reverse and may be reasonable in some cases such as for very tall drivers.
Originally Posted by SPB Rule 7B
All interior items and insulating material may be removed except where otherwise noted. Doors may be gutted, except factory door beams must be intact or protruding intrusion door bars must be added to the cage.
Originally Posted by SPB Recommended Rule 7B
All interior items and insulating material may be removed except where otherwise noted. Doors may be gutted, except factory door beams must be intact or protruding intrusion door bars must be added to the cage. Interior metal components welded directly to the frame or floor must be retained.
Originally Posted by SPB Alternative Recommended Rule 7B
All interior items and insulating material may be removed except where otherwise noted. Doors may be gutted, except factory door beams must be intact or protruding intrusion door bars must be added to the cage. The spot welded interior floor seat mount brackets may be removed.
3. Rear Metal Bumper Removal - Clarify wording to make it clear that if the factory metal bumper is removed, a steel beam either must or may optionally replace it. I assume right now some run without them and feel it's justified and others feel a beam must be in the car to stay legal. Note that regardless, because the steel reinforcement is not presently defined, nearly any piece of steel could in theory meet the present rule.
Originally Posted by SPB Rule 6E
Headlights, tail lights and brake lights must remain stock; license plates, frames, and license plate frames may be removed. Rear bumper cover, license plate area may be cut out to 27” wide by 7” tall maximum. Tow hook hole maximum 6” x 3”. The rear metal bumper may be removed, and a steel reinforcement added in its place.
Originally Posted by SPB Recommended Rule 6E
Headlights, tail lights and brake lights must remain stock; license plates, frames, and license plate frames may be removed. Rear bumper cover, license plate area may be cut out to 27” wide by 7” tall maximum. Tow hook hole maximum 6” x 3”. The rear metal bumper may be removed and replaced with a steel reinforcement of at least XXX dimensions.
Originally Posted by SPB Alternative Recommended Rule 6E
Headlights, tail lights and brake lights must remain stock; license plates, frames, and license plate frames may be removed. Rear bumper cover, license plate area may be cut out to 27” wide by 7” tall maximum. Tow hook hole maximum 6” x 3”. The rear metal bumper may be removed, and a steel reinforcement may be added in its place.
4. Dashboard Removal - The present wording left Lemming and I thinking the dash can be removed. Most cars keep them. If the intent of the rules is to require racers to keep them, this should be reworded. Right now "factory dashboard instrument pod" leaves dashboard acting as an adjective clarifying the location of the instrument pod, so I read it to say I need the factory instrument pod = factory gauge cluster and essentially nothing else. This was my honest first read, not an intentionally creative interpretation.
Originally Posted by SPB Rule 7A
Factory dashboard instrument pod must remain intact; 996 instrument cluster is allowed. Additional gauges may be added.
Originally Posted by SPB Recommended Rule 7A
Factory dashboard instrument pod instrument cluster must remain intact; 996 instrument cluster is allowed. Additional gauges may be added.
Originally Posted by SPB Alternative Recommended Rule 7A
Factory dashboard and instrument pod must remain intact; 996 instrument cluster is allowed. Additional gauges may be added.
5. Washer System - For completeness I'd like to see the windshield washer system removal explicitly permitted as part of the wiper removal rule 6J. It's easy to assume, but the present rule does not allow it.
Originally Posted by SPB Rule 6J
The windshield wiper arms and blades may be removed.
Originally Posted by SPB Recommended Rule 6J
The windshield wiper and washer systems may be removed.
6. Removing Bolted Assemblies from Front and Rear Trunks - I was not able to find anything about removal of the carpet, insulation, and bolted assemblies from the trunks in the rules. This includes pieces like the plastic battery cover, the rear trunk stereo amplifier, and so forth. It is done by all and is expected. It may be worth defining the area covered by the front and rear trunks as part of the interior under rule 7B.
All interior items and insulating material may be removed except where otherwise noted. The interior includes the cabin and the areas immediately underneath the front and rear trunks. Doors may be gutted, except factory door beams must be intact or protruding intrusion door bars must be added to the cage.
7. Engine Cover - Consider explicitly allowing and recommending use of the Cayman metal engine cover under rule 7I. I don't have time to grab the part number or I'd include it here.
Old Apr 20, 2017 | 06:49 AM
  #162
968workaholic's Avatar
968workaholic
The floor seat bracket removal is allowed under the appendix for using a FIA seat without a back brace and being further than 3 inches from the firewall.
Without the factory dash in place, or something similar, the interior looks un - finished imo. It really doesn't weigh that much anyway
The Cayman engine cover would add cost to the build, and it is lighter as well
The front and rear trunks are considered part of the interior imo
As for the washer system, that should be include that it can be removed
The rear bumper and radiator fans are a gray area indeed, something to bring up when the mid year rule proposal changes come around.
Old Apr 20, 2017 | 03:49 PM
  #163
audipwr1's Avatar
audipwr1
I cut out my seat rails - my car was heavily scrutinized multiple times and no PCA tech had an issue - tall people need the space
Old Apr 21, 2017 | 08:27 AM
  #164
Streak's Avatar
Streak
Perfect Angel
I'm 6'3"
Blah blah blah
Old Apr 21, 2017 | 08:34 AM
  #165
toddlamb's Avatar
toddlamb
Former Vendor
Originally Posted by Streak
Blah blah blah
This thread is for Spec Boxster racers only!
