Spec Boxsters For info sharing on this exciting new class
Transmissions
Old May 16, 2016 | 10:20 PM
mmuller's Avatar
mmuller
I run a cooler and change the oil every weekend. Cooler, when done right, adds a level of circulation and spray onto the gear set which in itself helps a lot. Finding ways to remove heat from the gearbox will help its life tremendously.
I have only done one trans (probably will do another one now that I typed that) last year at VIR when it was 95. Car ran great and set a new lap record. Next morning in the heat, 3rd gear synchro melted on lap 5 while out in front. No indication prior, it had just had enough.
Old May 16, 2016 | 10:33 PM
Gary R.'s Avatar
Gary R.
The data now points to a 3.2 being the deciding factor on G86 transmission failures...
Old May 17, 2016 | 04:38 PM
Greg Holmberg's Avatar
Greg Holmberg
I just thought California Motorsports might have an opinion about the causes of failure, and so how to prevent them.
Old May 17, 2016 | 10:07 PM
bkovac's Avatar
bkovac
Matthew i sent you a PM
Old May 17, 2016 | 10:19 PM
audipwr1's Avatar
audipwr1
left you a voicemail
Old May 17, 2016 | 10:20 PM
audipwr1's Avatar
audipwr1
I run a cooler and change the oil every weekend. Cooler, when done right, adds a level of circulation and spray onto the gear set which in itself helps a lot. Finding ways to remove heat from the gearbox will help its life tremendously. I have only done one trans (probably will do another one now that I typed that) last year at VIR when it was 95. Car ran great and set a new lap record. Next morning in the heat, 3rd gear synchro melted on lap 5 while out in front. No indication prior, it had just had enough.
Yeah it was 90, synchro has been slowly going last three weekends eventually wouldn't go in, was also running just fine prior, slowing my shifts was costing me time though
Old May 17, 2016 | 11:28 PM
mmuller's Avatar
mmuller
Sorry, didn't get it. Give it another go.
Old May 18, 2016 | 12:56 AM
audipwr1's Avatar
audipwr1
Wrong Matthew :-) I am the other SPB Matthew
Old May 18, 2016 | 08:45 AM
mmuller's Avatar
mmuller
That explains it then. My bad
Old May 19, 2016 | 10:08 PM
bkovac's Avatar
bkovac
Matthew I sent you a PM, call VALI. He has someone that does great work. With that said I always carry a transmission. I have seen a driver go thru 3 transmissions at the POC buttonwillow race last year.
Old May 20, 2016 | 10:51 AM
audipwr1's Avatar
audipwr1
Thanks I just bought a few spares
