Spec Boxsters For info sharing on this exciting new class
Running square
Old Jul 15, 2016 | 01:57 AM
Coloradoheel's Avatar
Coloradoheel
Square has to be 255 40/17.
Fastest lap I've ever laid down at High Plains was my first ever club race with a staggered setup. I've run square since I was able to get the wheels. Still can't match that lap.
Old Jul 15, 2016 | 12:24 PM
ninjabones's Avatar
ninjabones
Originally Posted by sbelles
I've gone both ways.
too easy scott.
Old Jul 15, 2016 | 12:31 PM
sbelles's Avatar
sbelles
I'm in....
Originally Posted by ninjabones
too easy scott.
Yeah, I knew that was a softball when I threw it out there.
Old Jul 15, 2016 | 12:59 PM
Aspen Autosports's Avatar
Aspen Autosports
Former Vendor
Running square is more of an optional set up. High Plains looks pretty fast with only a few tight corners that would require a ton of front end grip that the square set up will give you. Going staggered in those situations will reduce your aero disadvantage from the front tire hanging slightly out of the wheel well.
Figure tight technical courses square will be faster. Wide open fast flowing courses staggered will be faster.
Old Jul 15, 2016 | 01:03 PM
Gary R.'s Avatar
Gary R.
Not that there's anything wrong with that, you do drive a Boxster after all!
Old Jul 15, 2016 | 01:10 PM
ianacole's Avatar
ianacole
Veteran: Air Force
Are you on the gas coming out of 2 all the way through 3 and onto the straight, or do you lift a little for 3?
Old Jul 15, 2016 | 02:06 PM
sbelles's Avatar
sbelles
I'm in....
And I look fabulous in it!
Old Jul 15, 2016 | 10:53 PM
Coloradoheel
100% on the gas from exit of 2 until brake for 4.
Old Jul 18, 2016 | 01:29 PM
ianacole's Avatar
ianacole
Veteran: Air Force
Nice! Haven't gained that level of confidence in the bone stock boxster yet.
Old Jul 18, 2016 | 04:00 PM
Coloradoheel
might be more of a challenge in a stock box.
