Spec'ish Boxster FS
Decided to sell my "Spec" Boxster. This car is mechanically spec compliant but has aftermarket bodywork, most of it carbon fiber. Should be quite easy to sell the CF goodies for quite a bit more than stock 986 parts if you want to go all spec. Never raced, only used for some DEs. Here are the highlights, please PM with questions.
- Appr 2400lbs wo driver.
- CF Front bumber cover with side radiator vents, front fenders, hood, doors and rear hatch.
- Techart rear section
- Fiberglass top
- Recently rebuilt PSS9s with swift springs
- Adjustable sway bars with Tarrett drop links
- Front GT3 lower arms
- Rear adjustable toe link
- All discs new Sebro slotted and coated
- All brake pads new Pagid Yellow
- Steel spun brake lines
- New front wheel bearings, rear has very little time on them
- 4x 8.5 wide wheels
- Almost new Schroth harness, Schroth center net, Window net included but not yet installed
- Sabelt seat, no significant wear
- IMS just replaced with Eternal IMS w oil feed
- New RMS
- 4" underdrive pulley w/ new belt
- X51 oil pan
- New water pump
- New idler pulleys
- Light weight exhaust
- Fully stripped harness with push start
- Fresh alignment
- A/C delete
- SAI delete
Pictures available here (pm for more):
https://goo.gl/photos/urKvaEJJhBX2J6ZS7
Asking $29,500:-
- Fiberglass top
- New RMS
- X51 oil pan
- New water pump
- New idler pulleys
- Fresh alignment
- A/C delete
- SAI delete
Asking $29,500:-
