Spec Boxsters For info sharing on this exciting new class
Wanted: car for build
Old 01-05-2017 | 01:16 PM
Lemming's Avatar
Lemming
Pick up the car next week. I'm not going to try to do a rapid build, should be PCA race ready for 2018 but likely run and tested many times prior.
Old 01-06-2017 | 10:42 AM
toddlamb's Avatar
toddlamb
Basic Site Sponsor
Good luck with the build - let us know if you need anything....and we'll be over to Barber several times this spring if you need something delivered.
Todd Lamb
Atlanta Speedwerks
www.ATLspeedwerks.com
Porsche repairs, servicing, and upgrades / Certified IMS installer / PDK repair experts
Over 150 PDK's repaired and counting:
https://youtu.be/m54P_zisEcI
Old 01-07-2017 | 08:17 PM
Lemming's Avatar
Lemming
Will do. Let me know when you are coming over, I'm local and attend just about every Barber event.
Old 01-07-2017 | 09:08 PM
toddlamb's Avatar
toddlamb
Basic Site Sponsor
Looks like March 4-5 for Global MX-5 test and then April 21-23 for the Global Mx-5 race (with Indycar)
Old 01-15-2017 | 09:10 AM
Lemming's Avatar
Lemming
Picked the car up on Tuesday, flushed brake system, added front rotors, changed the oil, tossed on my 981 track wheels and yes, it's already at the track to see if it runs. Good news is that everything works and the car runs great. Not bad for $2,999
Old 01-16-2017 | 12:48 AM
morsini's Avatar
morsini
This is the way I think it should be done!
Old 01-16-2017 | 01:39 AM
hf1's Avatar
hf1
Well done! Good luck with the build!
Old 01-16-2017 | 02:44 PM
Gary R.'s Avatar
Gary R.
That's a heckuva start for an SPB build! You could end up under $30k for a top car (assuming engine/trans are 100%) if you do a lot of work yourself!
Old 01-17-2017 | 11:27 AM
Lemming's Avatar
Lemming
I will be doing all the work myself, also have quite a bit of stuff that will transfer over from my 944LS that I parted (seat, steering wheels, accusump, etc). Traded 4 9x17 cupII's to a friend for 4 8.5x17 BBS wheels as well.
I will be heading to the dyno soon to get base data. Lot's or parts ordered and on their way.
Old 01-17-2017 | 11:33 AM
Lemming's Avatar
Lemming
Dropped 50 lbs of weight this weekend at the track when I pulled the subwoofers
Old 01-17-2017 | 11:51 AM
HoBoJoe's Avatar
HoBoJoe
Wow, that's ridiculous.
Old 01-24-2017 | 12:46 PM
Lemming's Avatar
Lemming
Got a set of BBS wheels from a friend, traded some cup II's for them. I had some used Toyo RR's to mount on them already.
Found 4 twists on Ebay for an average of $100/each shipped
And my Bilsteins arrived yesterday. It's going to be a busy weekend.
Old 01-24-2017 | 01:15 PM
Gary R.'s Avatar
Gary R.
I like the BBS the best (as you can see in my Av), but the Twists allow you to bleed your brakes without removing the wheels!
Old 01-24-2017 | 02:31 PM
Lemming's Avatar
Lemming
I like the look of the BBS as well, but will hate cleaning them.
Almost forgot, found a lightly used FVD
Old 01-26-2017 | 11:09 AM
Lemming's Avatar
Lemming
Worked on the seat mounting last night. Tried to mount to stock sliders, I got it to work but the seat was far to high, so I ended up with a solid mounting. The seat is starting to look a bit ratty, time to get a new cover from Racetech.
Quick Reply: Wanted: car for build
