VIN:WP0CA2984VS625818
Car color: Silver (currently wrapped n Black Satin vinyl) - Car #121
Mileage: 61,264
Bilstein PSS9 Spec Boxster suspension
GT3 front sway bar
GT3 front control arms
Tarett Engineering front and rear adjustable drop links
Tarett Engineering rear toe control arms
Slotted brake rotors
Stainless steel brake lines and GT brake ducts
Pagid Yellow brake pads
3rd (center) radiator
Wevo semi-solid transmission mounts
LN Engineering Deep sump upgrade and oil starvation pickup
Spec Boxster race exhaust system
Rebuilt Transmission - 4 days DE time on it
IMS installed (03/2020)
New plugs, new coils, new clutch lines, new brake lines, new drive belt, new clutch slave (03/2021)
New Fuel Pump & Tank Sender Assembly (09/2021)
Chome-Moly roll cage by Conway Autoworks (CT) - to current PCA SPB spec w/ SFI compliant padding
Fiberglass hard top
Roof safety net
OMP Velocita Superleggera steering wheel with quick disconnect
AIM MXL dash (mounted in front of existing dash)
Sparco Circuit II seat
Schroth harness (expire end of 2024)
Spa Design - Spa Extreme fire suppression system
Demon Tweeks Kill Switch included (not installed - previous switch died)
Hood Pins
Transponder (Mylap X2)
Extra wide angle rear view mirror (170 degrees)
1 set (square) Toyo RR
1 set (staggered) RA-1
Passenger seat is available
VBox was moved to my new car, there is no data system included
CoolSuit was moved to new car, no cooler or shirt, etc included
