Garage cleaning, some special boxster parts available
Just cleaning the garage, found a few things available from the boxster
1. Set of old PSS9 shocks with the Eibach 450/500 springs. It has everything you need to put it into your car except the front thrust bearing at the top. No leaks, but all the adjusters came off and I only have one **** remaining. $550
2. A set of GT3 Control Arm (4), all have good center bushing, but two has bad ball joints and they need to be replaced. $1000 for all 4? I found a place that will replace the ball joint for $225
