Hot restart issue SPB
Anyone ever have hot restart issues w/ their SPB? I did at the UMC club race, had to push start after sitting waiting for the scales. Hot day, altitude, and engine temp after sitting/idling/heatsoak was pushing 250. Trying to decide if it's starter related or resistance in the starter wires from heat. I have a new starter (last winter), Bosch rebuilt in the car. Certainly could be a dud. I recall the 996's had problems w/ hot restart due to resistance in an aging starter-alternator cable, wasn't sure if that is an issue w/ 986s too. Cable is different P/N vs the 996.
When cooled and the following day races x2 it started fine at post-race hot engine temps around 210-215.
Basic Sponsor
I have heard of this issue before and I learned the solution was to replace the failing 11lb BRAILE battery with a new one. Makes sense to me its electrical related (battery or bad ground).
rennpart.com | Phone: 336-793-2134 |Email: ace@rennpart.com | totalbrakes.com
FSI - LN Engineering Certified IMS Solution Installer
Instagram | Facebook
I have noticed the starter turning over a bit more slowly when the car is warm but it does start. That seems to support the wiring resistance.
That being said I have had these batteries die on other cars by 1 year. I always trickle charge it at home.
I'm digging into the same issue now, ran an enduro would start 3 of 4 times, then not at all, then 1x. Got so bad I actually hired a kid to 'crew' and basically push start me every session @ NJMP 2 weeks ago.
Tried charging, tried swapping (full size) battery. AIM shows 13.1v or better. I'm going to go after all the cables to-from the alternator and possibly the alternator itself over the next week or two.
Update:
Pelican says the cables are NLA from Porsche (ugh!).
986-607-029-00-OEM - Starter/Alternator Cable
986-607-030-00-OEM - Engine ground strap
Checking w/ Auto Atlanta to see if they can get them. They often have come thru for me in the past on NLA parts.
In the mean time once I get the original cables out I will measure cold resistance on them. Could stick them in the oven then measure again to compare when hot.
New/rebuilt warranty Bosch starter arrived yesterday.
Update:
Checking resistance is a difficult way to test a cable.
The best way to test a battery cable to pull a lot of current through it and see if the ends get hot. You will need a carbon pile (or similar) battery tester. Connect the cable and battery tester in series with a fully charged battery.
Be careful as a bad connection can get really hot.
Audi sold some nice 5 cylinder diesels in the late seventies and early 80s. Unfortunately, they would start poorly in a Minnesota winter. When I would get a non-starter the first thing I would do is hook up some jumper cables and crank the engine for 20 or 30 seconds without waiting for the glow plugs to cycle. I would then carefully feel the ground cable ends. (The ends on the ground cables were crimped without solder and the road salt would get in there and ruin the connection.) I would use a wire wheel to buff the copper shiny and then solder the connection.
After a while I quit testing and just looked to see if the ends had been soldered. It was a quick easy repair and I could bill an hour. Those diesels were pretty popular and I made a lot of money.
Good for the customer too as Audi was happy to cover this repair under warranty.
