Front Wheel Bearing Issues
Hi Guys,
We have a Boxster S we run in a series in Canada (Area 27) that we are continually having to replace front wheel bearings, we have use factory as well as aftermarket bearings with the same result.. Is anyone else having issues with front bearings?
The series runs a spec Continental street tire (340 Wear rating) so the forces are nowhere near as high as you would get with a sticky tire.
Any help, guidance is appreciated.
We ran a SPB in endurance series for quite a few years. One thing we did was replace the grease in the new bearings before install. Krytox is $$, but helped for sure. Replaced the bearings after 4K miles, just part of the service schedule. You should do better than we did on the rears, as the S uses bigger rear bearings. Another thing we did was have a second set of wheel carriers built and ready to go. makes the swap much easier if you lose a bearing over a race weekend.
@Bull_D Thanks for the quick reply.. We are not even making a season on a set of front bearings.
How difficult is it to replace the grease? Do the seals go in and out relatively easily?
That's awesome, the cost really isn't an issue it's the time, I really like the idea of the second set of uprights.
We always freeze the bearings and use a little anti-seize, this and a press makes light work of the install. The hotplate is a great idea!!
I think Grease shaming in this case is appropriate... whimpy it is
tgsmith4845 (10-04-2021)
I have made a tool that makes greasing the bearings a 5 minute job. I found a 2000 mile service life was realistic with stock grease. They go much farther with Krytox. I did not test CV2.
Chris
Chris
Whar kind of tool did you make? I preemptively replace all 4 bearings in the off season, and am interested in your tool to make the job easier.
Thanks,
Tim
Honestly, its a non issue. First one might take a few minutes to get apart but after u figure out how it comes apart, it takes a 90 degree pick and 90 sec to disassemble.
I'm in....
+1 The seal is pretty robust. Don't be afraid to apply a little pressure. What will surprise you is how little grease is in there.
