Best location for Trans Cooler heat exchanger
Hey all!
My new-to-me Spec Boxster has a trans-cooler installed (thank you, Dean). However I'm not sure if the current location of the heat exchanger is ideal, as it is mounted to the underside of the trunk floor. I'm sure that location was selected because it it can see the fresh air on the other side of the mesh grill in the bumper-center cutout, but I'm not sure it's close enough to the opening to really see any benefit. In the meantime, the exhaust is right below it, and I'm afraid the heat coming from that might be undoing any cooling effect.
Where do y'all typically mount your heat exchangers for your trans coolers?
Maytag (02-21-2021)
@Maytag Drive it. Use one of those temp strips (Tatum has I believe or the website named for the large South American River) to see where you get, temp-wise. On previous builds, I was told they found that temps weren't excessive so they bagged the cooler. Could be that for relatively short sprint races/sessions not an issue - for Enduro may be a different story.
Maytag (02-23-2021)
I'm machining an adapter today to put a temp-sender in, and adding a gauge. (I'm already adding an actual VDO Oil Press & an Oil Temp gauge, as well as an indicator light for when the accusump is "open").
In the meantime, I'm going to move the cooler to the left-corner of that area, so it's not directly above the exhaust, but still has sight of the "window" in the rear bumper.
Enduros are going to be the biggest part of my weight-loss plan for the foreseeable future.
I'm only days away from having this thing ready to go. New seat, harness, fluids, once-over on all the nuts-n-bolts, boots, rubber-goods, brakes, etc etc etc. I know: I cheated. hahaha.
martt1ski (02-24-2021)
