Race fuel
while crewing for a SPB Sunday at the Daytona race, I noticed that some teams were using race fuel in their SPB. Is this allowed because it does not say it can be used in the rules that I can find?
Perfect Angel
Our rules don't specify what fuel you can use. Some use 98 or 100 because it runs cooler but gives no power advantage since we cannot monkey with the ECU at all.
Make sense?
After a quick scan the only class that seems to specify fuel is SP911
Make sense?
I thought the rules are if it is not said, you can not do it.
Also if you are running 98 or 100 octane, the ecu adjusts for it just like if you had 87 octane the exu adjusts for knock
The long and short of it is that you want as little octane as possible to eliminate detonation.
https://www.hotrod.com/articles/0901...pump-race-gas/ does a pretty good job of explaining.
Now given that track use will cause the overall engine temps to be quite high, the race fuel offers a bit of margin for error if your car may like to detonate a bit when warm, but if not, you don't gain any power and may actually lose some.
Additionally, the stoich a/f for race fuel is different.
Correct, there is no "tune timing for more octane" program in the ECU.. My logic was to use it on hot days to help avoid detonation and the loss of power the ECU will cause when adusting the timing for it. On my Stock D 911, with no ECU or knock sensors, I used to to help avoid detonation, period. Usually blended the 93 with it.
So, what does this mean for our stock 2.5l SPB motors? I thought I read/heard that the TX guys tested a few years ago and found that 93-94 octane was best?
