Spec Boxsters For info sharing on this exciting new class
Methods to seal roof to top of windsheld frame
Old 04-18-2018, 12:56 PM
Matt Marks
Matt Marks's Avatar
Default Methods to seal roof to top of windsheld frame
I'm starting my cage build in a couple of weeks and just ordered the GT Racing roof. I see that there are lots of ways to set up roof attachment to the rear portion of the cage, but does anyone have comments or pictures of how the roof is attached to the from windshield frame, and if anyone is using some sort of seal to prevent water leaks into the cockpit when running in the rain? Also ideas as to what to do with the clamshell to make it easily removable for quick unfettered access to the engine compartment rather than having to work around it using the stock mounts.
Thanks!
Old 04-18-2018, 01:45 PM
jdistefa
jdistefa's Avatar
3-4 dzus fasteners and then simply use Gorilla tape to seal
http://www.uk.gorillaglue.com/gorill...pair-duct-tape
Old 04-18-2018, 10:58 PM
Lemming
Lemming's Avatar
I had dzus fasteners on my all my race cars, but not this one. Since the top does not need to come off in a hurry, I simply used well nuts and screws (two on the front, two on the rear). Takes a few seconds longer, but they don't pop open in the middle of the race, which has happened to me with dzus fasteners.
My clamshell is intact, not a problem so far. I manually pull it back out of the way when working in the engine compartment.
Old 04-19-2018, 08:53 AM
mmuller
mmuller's Avatar
I use 4 Aero Catch's. @ by the windshield on one on each side.
No way my top is coming off
Old 04-21-2018, 09:58 AM
sbelles
I'm in....
sbelles's Avatar
+1
1/4 turn Cam-lock type fasteners work great and I don't need to tape. That is until I lost a couple. My advice is to buy extras.
P.S. Anybody know who made this and where I can find some? I've found a lot of similar ones but not these. Panal hole is 7/16" , the depth is ~ 5/8" when latched and the coller is 7/8"
Old 05-12-2018, 12:41 PM
JML47
JML47's Avatar
McMaster Carr would be a good bet. That’s where I got my Dzus fasteners, which have worked well for my fiberglass Boxster roof, btw. Three across the front, one on each side.
Old 05-12-2018, 12:50 PM
Matt Marks
Matt Marks's Avatar
Are they into tabs welded to top of windshield frame? Or to cage?
Old 05-12-2018, 01:52 PM
sbelles
I'm in....
sbelles's Avatar
Mine are on the windshield frame.
Old 05-13-2018, 11:11 PM
Bull_D
Bull_D's Avatar
foam rubber "P" seal. works like a champ. run it along the windshield frame below the roof. no need for helicopter tape or the like on the outside.
https://www.mcmaster.com/#catalog/124/3589/=1ctx9n2 it is the top material on this webpage
Old 05-14-2018, 08:09 AM
Lemming
Lemming's Avatar
Windshield frame.
Quick Reply: Methods to seal roof to top of windsheld frame
