Spec Boxsters For info sharing on this exciting new class
Best (reasonably priced new/used) short shifter for Spec Boxster
Old 02-15-2018, 05:03 PM
alpinaturbo
alpinaturbo's Avatar
Default Best (reasonably priced new/used) short shifter for Spec Boxster
Gentlemen,
May I solicit advice, what is best short-er shift / more precise shifter for spec Boxster?
Something new or used, not terribly expensive (Like CAE as example).
Thank you
Old 02-15-2018, 05:58 PM
audipwr1
audipwr1's Avatar
987s
Old 02-16-2018, 12:39 PM
alpinaturbo
Many thanks Audipwr1
Old 02-16-2018, 06:17 PM
mmuller
mmuller's Avatar
I would use the 997.2RS shifter. Metal bushings, short shift and one of the cheapest
Old 02-16-2018, 06:39 PM
audipwr1
audipwr1's Avatar
Interesting - is that what you run Matt?
Old 02-16-2018, 11:44 PM
mmuller
mmuller's Avatar
Its what we run in all our cars. Best shifter you can buy. Short and precise. Just like an RS. Put some Numeric cables with it and you have almost RS level shifting
Old 02-17-2018, 08:47 PM
ace37
ace37's Avatar
If shift feel is the goal, you can always get metal bushings. I installed these in the factory shifter: https://phenixengineering.com/shop/p...t-bushing-kit/
Old 02-17-2018, 09:21 PM
mmuller
mmuller's Avatar
Or just by the factory RS shifter. It has them already installed. Last one I bought was less than $400 for the whole shifter
Old 02-18-2018, 05:31 PM
alpinaturbo
Better then B&M?
So 997 GT3 shifter assy for example?
I know some company was offering just the shifter components to update our shifters, or also offered complete units as a swap (core perhaps is sent to them).
Was like $250 or so, seems like nice way to also upgrade.
I am not inclined to buy new cables also, if originals work well.
Old 02-19-2018, 12:15 AM
mmuller
mmuller's Avatar
Originally Posted by alpinaturbo
Better then B&M?
Don’t use a B&M unless you enjoy replacing expensive components like transmissions and motors. They are not a good design, significantly increase shift effort which has a higher chance of a missed shift (motor go boom) or grinding of gears, which in our transmissions is a death bell.
Shift cables led are not needed unless looking for another step up in shift performance. Remember, every split second out of the gas is a loss of momentum.
Old 02-19-2018, 02:51 AM
alpinaturbo
Thank you for saving me trouble...OEM than, GT3 or 987/997.
Old 02-22-2018, 10:03 AM
RennPart
Basic Sponsor
RennPart's Avatar
Do you chew up transmissions faster with a short shifter? I used the stock 100k miles shifter and cables last year, have a 987 shifter that I'm thinking we will try this year.
rennpart.com | Phone: 336-793-2134 |Email: ace@rennpart.com
Instagram | Facebook
Old 02-22-2018, 10:21 AM
mmuller
mmuller's Avatar
The B&M shifter increase shift effort which increase the chance of missed shifts or grinding gears and therefore induces a higher chance of killing a trans. The OEM short shifter's do not increase shift effort so have no impact here.
Old 02-22-2018, 06:46 PM
hf1
hf1's Avatar
Received 1,639 Likes on 1,122 Posts
Are these still available new, or where would you source them?
How do cables make a difference? What makes one cable better than another?
Thx!
Old 02-22-2018, 07:25 PM
mmuller
mmuller's Avatar
Should be available anywhere selling Porsche parts.
Thx!
The cables are twice the thickness with stiffer ends on either end. The end result is less slop and more precision in shifting. They are the same makeup as the 996 Cup Car cables which have a similar improvement metric for GT3 car's
Quick Reply: Best (reasonably priced new/used) short shifter for Spec Boxster
