Spec Boxsters For info sharing on this exciting new class
ECU flash - now legal
Old 10-15-2017 | 11:45 AM
Lemming's Avatar
Lemming
Default ECU flash - now legal
At the NOLA race there were a few people discussing the euro flash and potential power gains. Looks like the flash is now legal, but PCA rule announcement states that there is no gain in power. Anyone know if this is true? Where dynos done to compare?
SPB
Any of the Porsche flashes, including European or other country flashes, for any SPB eligible model may be used. In terms of performance, all the factory flashes are equal. The differences relate to emissions or other matters, and the European flashes throw fewer codes because they had fewer emission control devices. Fewer codes makes using the OBD system less cumbersome.
Old 10-15-2017 | 01:51 PM
Frank 993 C4S's Avatar
Frank 993 C4S
SPB
PCA sampled data to compare.
Old 10-15-2017 | 07:21 PM
CTS's Avatar
CTS
I have verified this. There is no change in how the engine runs.
Chris Cervelli
Cervelli Technical Service
Old 10-16-2017 | 07:44 AM
smsarchitects's Avatar
smsarchitects
If there is no change and the US flash is readily available then why allow a Euro flash ?
Old 10-16-2017 | 08:57 AM
Lemming's Avatar
Lemming
Chris Cervelli
So there were dyno runs to look at power output?
Old 10-16-2017 | 10:32 AM
HoBoJoe's Avatar
HoBoJoe
The euro flash will keep the ECU from throwing codes when there is an issue with the secondary O2 sensors. However, if you just tie them out of the way you won't get a CEL.
Quick Reply: ECU flash - now legal
