Picking off measurements from OBDII
I was wondering if in the SPBs we can pick off Oil Pressure, Oil Temp, Water Temp, Tranny Temp off the OBDII?
Let me clarify -- what I am after is physically splicing a wire and routing that to my Traqmate as a digital or analog input.
I'd prefer to send the to my Traqmate data logger and TD rather than add a bunch of gauges and new senders (unless I have to)
thanks,
Mike
thanks,
Mike
The sensor wires themselves go to the DME in the trunk. If you could find the voltage parameters, you could easily tap into the wires and get that information. Looking at the wiring diagram, I can see inputs for oil temp, oil pressure, air intake temp, water temp, engine bay temp, etc.
Traqmate is fairly limited, can't read CAN data as far as I know. I have a Traqmate, and am pulling rpm off the tach signal, and throttle position off the TPS signal. For brake pressure I installed an AEM 2000 psi brake pressure sensor and Bodymotion BMR1001 adapter.
Where do you find the TPS signal?
do you have a link to the Bodymotion BMR1001 adapter.
Searching did not provide an answer.
Is there a steering angle sensor tap off?
thx,
mike
Basic Site Sponsor
Basic Site Sponsor
No steering angle from OBD.
Throttle position is off throttle body; Have to splice in. We make a throttle position cable for AIM.
And we make a brake pressure adapter line for most sensors.
If I recall you can get water temp / oil pressure off the OBD but it’s low frequency.
Todd Lamb
Atlanta Speedwerks
www.ATLspeedwerks.com
Porsche repairs, servicing, and upgrades / Certified IMS installer / PDK repair experts
Over 150 PDK's repaired and counting: https://youtu.be/m54P_zisEcI
Todd Lamb
Atlanta Speedwerks
