91 S4 Instrument Panel Face is delaminating
Old 11-13-2014, 02:21 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Default 91 S4 Instrument Panel Face is delaminating
I pulled the instrument panel from a 91 S4 I imported from Nevada and upon inspection it looks like the top layer is delaminating. I have never seen this before. Is there something I can do or do I need to source a replacement?
Old 11-13-2014, 02:33 PM
SeanR
SeanR's Avatar
I've seen it once on a rather low mile GTS (mileage was not accurate) and know of no way to fix it. I'd try and contact someone at VDO and see if they can refresh it.
Old 11-13-2014, 02:37 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,557 Likes on 1,236 Posts
Or maybe North Hollywood speedometer (?)
http://www.nhspeedometer.com/
How much were the importation fees from Nevada? I hope the Federalization process isn't too painful.
Old 11-13-2014, 02:40 PM
NoVector
NoVector's Avatar
I had the same problem with my GTS. I got lucky and Mark had one during his 1/2 price December sale (928 Intl).
Old 11-13-2014, 02:48 PM
Tom in Austin
Tom in Austin's Avatar
Wow, never knew that possible
Old 11-13-2014, 03:45 PM
MGW-Fla
MGW-Fla's Avatar
I've followed this problem of the film on the face of the cluster delaminating for a few years. I've only seen it on 90' & 91' 928s & 911s. My '91 has it; just got a replacement cluster housing this week from 928 Int. I don't know of any other way to fix it but to replace the housing. Its just cosmetic, no effect on the operation of any of the gauges but it just doesn't look too great.
Old 11-13-2014, 03:48 PM
SeanR
SeanR's Avatar
It sure would be interesting if this was just an issue with the early digi clusters and was fixed on '92 forward. It would explain how a GTS with only 12k miles looked like it had a real rough 100k on it. Early cluster swapped in for the high mile one.
Old 11-13-2014, 04:16 PM
MGW-Fla
MGW-Fla's Avatar
I used to look at pics of '90-91' 928s & 911s for sale online to see if I could tell if they had this problem. Even kept a folder with the pics of other cars with the same issue. Saw it in one 911 & multiple 928s. I have asked many 928 Gurus & none said they've ever seen it.
Old 11-13-2014, 09:19 PM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
Mine does not have the issue. But then again, it's rarely exposed to extreme temperatures.
Another place to contact would be Palo Alto Speedometer: http://www.paspeedo.com
Old 11-14-2014, 01:30 AM
NoVector
NoVector's Avatar
I kind of wondered if it was caused by a leaking/loose fitting somewhere in the big HVAC hose that was blowing air (hot, cold, moist) into the pod area.
Old 11-14-2014, 06:58 AM
voskian
voskian's Avatar
Just checked a picture of mine when I got it two years ago and no delamination. I'll pull back the car cover this weekend ( snowing right now ) to see if there is any. My car also has not seen a lot of temp fluctuations and is low mileage. Mine was an early 1991 build # 127.
Old 11-14-2014, 07:43 AM
Madturk
Madturk's Avatar
I wish someone would make some color face inlays for this type of cluster like they have for the pre-89 style with some nice rings.
Even better a whole new instruments layout copied from the newer Porsches.
I would buy.
Old 04-11-2015, 04:14 PM
31-TL-ZS
31-TL-ZS's Avatar
Had mine done in the Netherlands at http://www.info-instruments.nl/ no affiliation. Looks great and is as new see pics, after and before this time.
Old 04-11-2015, 05:48 PM
NoVector
NoVector's Avatar
Thank you for posting! I'll e-mail them to see how much it will cost to repair my old one.
Old 04-11-2015, 05:51 PM
M. Requin
M. Requin's Avatar
I know this is OT, but that is one of your coolest avatars yet. Very subtle.
Quick Reply: 91 S4 Instrument Panel Face is delaminating
