Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
FS: PCCB Yellow 6 piston calipers - MINT!!!
Old 05-29-2013, 10:30 PM
powdrhound
powdrhound's Avatar
Received 1,792 Likes on 1,046 Posts
Default FS: PCCB Yellow 6 piston calipers - MINT!!!
Category: Brakes
Price (no $ sign please): $1650
Part fits (select ONLY those which apply): 911, 996, 997
Location (Region): Midwestern
Item Condition: Used
I have an extra set of MINT condition 997 GT2/GT3 PCCB 6 piston front calipers for sale. I had these as a spare set. These calipers were removed from a 2010 997 GT3 RS with less that 1000 miles on the clock. They have absolutely zero track use or nicks/scratches of any kind. The only way to get a cleaner set is to buy a new pair.
The part numbers are 997.351.431.92 and 997.351.432.92. Mounting hardware is included. The mounting bolt spacing is 225mm and the calipers are designed for 380mm rotors. Each caliper has 6 pistons with ceramic zircon inserts. These calipers will fit any 996/997 GT2/GT3/Turbo. The 996/997 Turbo cars will need to use the Porsche 997 Turbo bracket that comes on the PCCB cars. The brackets can be purchased at any Porsche dealer. The piston area of these calipers is 17% less than the 996 GT3 calipers thus giving a nice firm pedal. Retail is over $1200 each.
Price is $1650 plus $40 shipping insured CONUS. Buyer pays Paypal fees.
PCCB calipers by pwdrhound1, on Flickr
PCCB Left Caliper by pwdrhound1, on Flickr
PCCB Right Caliper by pwdrhound1, on Flickr
PCCB Left Caliper Top View by pwdrhound1, on Flickr
PCCB Right Caliper Top View by pwdrhound1, on Flickr
PCCB Left Caliper Rear View by pwdrhound1, on Flickr
PCCB Right Caliper Rear View by pwdrhound1, on Flickr
PCCB Caliper Hardware by pwdrhound1, on Flickr
powdrhound is online now
Old 05-30-2013, 07:21 AM
blockhed
blockhed's Avatar
Great seller....tempted
How are you stopping these days ¿
blockhed is offline
Old 05-30-2013, 08:14 AM
gray911
gray911's Avatar
I will take it if I can retrofit this on my 09 Carrera 2 3.6. Thanks.
gray911 is offline
Old 05-30-2013, 11:53 AM
powdrhound
powdrhound's Avatar
Got your PM with your VIN. I'll check with my parts guy to see if these would bolt up to your uprights. I'm pretty sure that you have the same 4 piston 146mm bolt spacing calipers that come on the 996TT in which case these would bolt up using the Porsche 997TT adapter bracket. That's what I use on my car.
Old 05-30-2013, 12:05 PM
powdrhound
powdrhound's Avatar
Stopping real well now.... Our track (HPR) is very hard on brakes. I changed over to the 997GT3 380/350 system at the end of last year. I use Giro 380/350mm floating rotors, PFC 08 pads, Endless RF650 fluid, and the 997 GT3 brake master cylinder. Brake pedal firmness, feel, and modulation are a day and night difference compared to the popular but rather mushy 6 piston 996GT3 350/350 set up. One of the biggest benefits with this set up besides thermal capacity is the fact that it shifts the brake bias to the rear by about 10% compared to the stock 996TT system. Cooling wise, in the front I run the 996GT3 Cup ducts and in the rear I run the 996GT2 brake ducts in addition to using the 997GT2 rear under tray which has NACA ducts and air guides that direct further air to the rear rotors.
Old 05-30-2013, 02:51 PM
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
A 996TT needs these...... !
TrackDays247.com is offline
Old 05-30-2013, 10:33 PM
gray911
gray911's Avatar
I did my research and retrofit is possible on a Carrera 3.6 but involves replacing the front wheel carriers. So, I'll pass on these. Thanks.
gray911 is offline
Old 06-10-2013, 05:16 PM
P_collector
P_collector's Avatar
hi powdrhound,
1) I suppose they fit for a 997 GT2?
2) Im looking for the aluminium hubs of the 997 GT2 or 997.1 GT3 RS PCCB brake discs..would you have these as well?
thanks,
P_collector is offline
Old 06-10-2013, 05:24 PM
powdrhound
powdrhound's Avatar
Originally Posted by Porsche.collector
hi powdrhound,
thanks,
1) Yes, these are factory 997 GT2/GT3 calipers
2) Porsche does not sell the aluminium hubs separately, only as part of the whole PCCB rotor assembly. Sorry....
Old 06-10-2013, 11:30 PM
Bullitt44
Bullitt44's Avatar
Pm'd
Bullitt44 is offline
Old 06-11-2013, 02:43 AM
powdrhound
powdrhound's Avatar
Originally Posted by Bullitt44
Pm'd
I have no PM from you...
Old 06-24-2013, 03:03 AM
rb4u
Former Vendor
rb4u's Avatar
Any idea for the cost of conversion brackets (adapters) in order to upgrade these calipers for my existing spindle and where I can get them.
Thanks
rb4u is offline
Old 06-24-2013, 07:30 PM
powdrhound
powdrhound's Avatar
Thanks
The brackets are a OEM Porsche part and can be purchased through any Porsche dealer. They are a little over $120 each if I recall correctly. I can get them very easily also through my parts guy..
Old 06-25-2013, 03:20 AM
Saadi996tt
Saadi996tt's Avatar
I'm interested, please give me your contact info. Can't send pm's yet, don't have enough posts.
Thanks,
Sk
Saadi996tt is offline
Old 06-25-2013, 07:48 AM
rb4u
Former Vendor
rb4u's Avatar
hi powdrhound,
thanks,
Are you talking about the rotor hat that attached to disc, if so may I ask what you intend to accomplish.
rb4u is offline
Quick Reply: FS: PCCB Yellow 6 piston calipers - MINT!!!
