Engine overheating
Yesterday my engine temperature suddenly began to quickly rise right after I had turned on the heater to eliminate a possible source of water pockets (mentioned in another thread I had started), so it happened I was watching the temperature gauge closely at the time. I was in town, only doing 35 mph. Fortunately I was close to home and immediately turned around and kept a close on the gauge. I arrived in the garage without the temperature rising much over 200. I looked for leaks (none), checked the coolant level (good) and pressure when removing the fill cap. The engine didn't have any unusual noises and sounded normal. The radiator had been recently serviced, topped up yesterday and the serpentine belt had been replaced and a sundry list of other items not related to this issue weeks earlier
I had just left the house, engine was cold, and it usually hits operating temp after about a half mile after starting up. I see two possible issues:
1) Radiator low speed fan(s) resisters had failed. The previous night it happened to be raining hard with the temps in the mid-60's. It was possible one of the resistors was hot and the internals broke after being struck by the water. So replacing the failed transistor will resolve the issue. Best to replace all of them at once than piecemeal, after all they are the original parts and resistors do deteriorate over time.
2) Thermostat isn't opening properly. Here replacing the thermostat and water pump as an added precaution (since it has to come out to replace the thermostat) since I don't know how old it is and when it was last replaced.
Can anyone else think of any more possible areas that might pose a problem? I can test the resistors, I can't test the thermostat (that I'm aware of), and I don't want to go through that expense only to discover there is another issue that is the root cause.
Thank you all in advance. I'm a virgin in the Porsche scene and I'm not yet familiar enough with all the foibles to watch for. My mechanic apprentice days were years ago working on MG's and Triumphs.
You need to update the water pump and the thermostat. A lot of people suggest a low Temp thermostat.
Secondly you should remove your front bumper, remove the air conditioning condensers and clear your radiators. You should do this twice per year. After autumn and before summer. Because of tree leaves, etc.
If you switched on the heating today, probably there was some air in there as well. Drive the car near your house with the maximum temp in your cabin make sure that it'll never goes towards the right because this is abnormal. You should hear the radiator fans starting, this means everything works fine. Check the photo below to see what is normal.
It is a normal procedure for a couple of days to have that metal switch behind the water bottle on the upper position. I am talking about this metal clip on the photo below. Move it up so that it stands because this lets the air get out. It is supposed to be at the highest point. I usually lift the rear of the car in order for the air to move from the radiators towards the back.
Clear your radiators. And verify that you don't see any milky stuff in your oil dipstick or cap. If you see water missing after a couple of days, concentrate on the smell. If you are familiar with burning water coolant smell, you might identify that the water is being burned somewhere and this is why you don't see it under the car.
I would pull the serpentine belt to make sure the water pump is turning smoothly and replace the thermostat (you do not need to remove the water pump to replace it).
Would also say that I don't think dirty radiators would cause an overheat - I cleaned mine for the first time in 20 years yesterday and it didn't really change anything (they were disgusting).
If your car is overheating, blasting the heat in a 996 will still contribute to cooling because the heater core effectively becomes a third (albeit very inefficient) radiator.
The dash guage is at best a refference and not very accurate. Get a scanner and read what the dme sees.
We know u probably have air in the coolant system....it still may be working its way out and an air pocket in the wrong spot can cause the gauge sensor to read steam temp if there is no flow.
If the fans do not operate with the AC on, then you may have a bad resistor. I think you can jumper the relay for the fans and make them run all the time if you want to do that, as well. There are threads and videos.
I am actually going to do this mod so I can turn them on at will - I am just waiting for the center console switches to ship to me. I can let you know how easy it is afterward.
You have some good hills in Greenville
You can find a good steep incline and get the back of the car uphill from the front, and it will help get air bubbles to the reservoir if there are any.
When I flushed my system I carried a gallon of pre mixed coolant in the frunk in case I had bubbles, so I could top it off if needed. It has not been necessary, but I was paranoid.
I am in Beaufort - happy to get on a call with you and discuss and try to help you. Message me if you want me to get on a call with you. I wish I saw this last Thursday, as I was traveling by on my way back from Tail of the Dragon in Deal. I could have stopped by.
Good luck. Keep us posted.
So my newbie panic has subsided.
My only experience with this is with MG and Triump's working 2 summers in a foreign car shop. That was 44 years ago. Can't claim I can remember all the details from that period if it were for my father having one of each that I did DIY work on.
According to your diagram it appear that I was completely wrong in my insertion. I'll keep that in mind for the future if I ever comment on the subject again.
I can learn from my mistakes
