Metallic Plastic on 6MT Knob Loose
Metallic Plastic on 6MT **** Loose
Has anyone else had a problem with the Metallic Plastic portion on 6MT **** becoming loose (see image below)?
Mine clicks in when pressing on it and now occasionally does this when shifting into gears 1/3/5. This started happening after I took the car in for service. Are there any known fixes other than replacing the entire **** and boot?
I may have answered my own question with more searching:
https://rennlist.com/forums/991-gt3-...ing-apart.html
I’d still be curious if anyone here knows of a fix other than a brand new **** and boot.
Is there another OEM shifter that would work well as a replacement?
I’d prefer not to go with an aftermarket option, if possible.
For example, would a 992 GT3 shift ****, or something similar, be compatible?
https://rennlist.com/forums/718-gts-...l#post17752598
Last edited by Westcoast; Today at 02:04 PM. Reason: added picture of GT3 shift knob
aarodynamics (Today)
Yep. I have a thread on here as well. I have yet to bring it in. I did pull it back and add some super glue but it did not help. Super annoying. Makes me want a PDK
https://rennlist.com/forums/718-foru...-me-crazy.html
As for the PDK comment, I would opt for hockey tape wrapped round the **** before going that route!
Mine clicked as well, I replaced it with one from a GT3.
Spoiler
As it stands, I'm leaning toward first trying to repair my original **** with some 3M Emblem & Plastic Adhesive unless someone thinks there's a better type of adhesive to use.
Nothing like putting the cheapest piece of the car on the object you touch 100 times when you drive. I've had 2 of the OP's and they both felt cheap. In the current car the wrap is leather and somehow it feels better and is more snug. If it because a pop can, I'll replace it with one like @Westcoast 's
I'd go with the 992 6MT shift **** in a second if they made one with red lettering. The yellow lettering works well in a car with yellow stitching and/or a yellow marker on the steering wheel.
I’ve bought the aluminum one offered on GTS models to go with the aluminum trim and it doesn’t feel bad, feels more robust than plastic one.
