Gas fumes
Gas fumes
'89 944 S2. I get gas fumes inside the car occasionally, but never smell gas anywhere outside the car or under the hood. I do not smell gas more strongly in the hatch area. There is no leak onto the ground and so far although I haven't torn the car apart I can't find anything. Any ideas that would save me some time are appreciated.
Lou
Lou
Tiger03447 (09-20-2024)
I haven't but I am getting gas fumes not exhaust fumes so haven't been leaning that way.
I checked the area around the fuel level sending unit yesterday and there were strong fumes from immediately around the sender. I pulled the sender and although the seal seemed fine I replaced it with one that is fuel grade of cork and rubber in the same thickness. I had to make it, the local Porsche did not have one in stock and I didn't want to wait one week. I just checked my work and there is still a smell there but not as strong. I was gas spilled over the top of the tank from removing the sender so I will give it another day to clear out and drive the car tomorrow. Then I will have a better idea of whether my work fixed the problem.
The fuel filler line that was also suggested is no longer available from Porsche.
self-made Special Tool 9190
Well this is interesting. Thank you. I am due to play around with a torch today, I think I will make a tool. There is no way I'm getting it to 26 ft. lb, and I imagine the hot water treatment loosens the fit up and gets things a little tighter before the 26 ft lbs comes up. I should have the new seal next week and may make a tool today.
thank you and I'll post how everything goes.
Lou
Lou
