torque specs
so as being the 5th owner and 2 of the priors had the car wrapped. i am still in the process of finding all the bits of wrap and goo left behind. also finding all the little things to fix. i honestly think over the next year or so as i refresh the car, ill end up pulling so much off the car. my question is, are there any bolts that have specific torque specs i should look out for? i have seen Raby's "Fastening Specifications" book for the 996 and couldnt imagine much would be that different out side of the motor. i have also seen various torque spec sheets based on the bolt size. im also assuming there shouldnt be much that deviated from those specs.
Mike was kind enough to post the workshop manuals for the 997 (and GT3 specifically) here: https://rennlist.com/forums/997-gt2-...copy-here.html
I'd recommend downloading the Google drive link and working through those. But if you have a specific bolt that you need a torque spec for, someone probably has the answer and you can ask.
If you really want to go down the rabbit hole, you can grab a copy of the 997 Torque Book from LN Engineering. I find it invaluable to quickly find a specific bolt’s torque value. https://lnengineering.com/997-torque...utomobile.html
