Weird Behavior with Windows on 981 BS
So I just had my 981 BS delivered a week ago, and I noticed some weird behavior going on with the windows. With the top down, and windows all the way down, when I open the door from the inside the window goes UP a little bit. Then when the door closes, it goes down. Its like its trying to compensate for when the window is all the way up, how it should drop a little. I also noticed the drivers side window switch inconsistently does the "1 touch up/down" functionality. Not sure if thats related or not. Any ideas here?
Cheapo911 (07-03-2024)
Wow if thats true, thats some amazing German engineering. I need to do more testing and see if it has issues with the top up and what not, but I've only had it a week and the top has been down 90% of the time.
It's correct behaviour. The one touch window up or down is just technique because the switches are two position. You need to make a positive selection for the full movement and light selections for partial operation.
