Was TPMS an option for 2017? No TPMS screen on 991.2
I recently purchased a 2017 C2 and it doesn't have a TPMS screen in the gauge cluster. There is no setting to add the TPMS screen or see tire pressure. I had thought they were required standard equipment since 2007. Am I looking in the wrong place and is it possible to retrofit?
It should be there. Keep scrolling through the display.
I've scrolled through multiple times and the available screens are - Vehicle, Audio, Phone, [Map], Navigation, Trip. I've explored all of the settings and submenus within the gauge cluster menu and there is no mention of tire pressure or TPMS. Is there something I need to do on the main PCM screen?
This should help.
The following 3 users liked this post by Tier1Terrier:
I can try taking a video but the other way you can tell I don’t have any more items is because I don’t have a scroll bar on the right side like you do
FYI, the little speedometer icon on the left side means is for your cruise control.
Ahh that’s a good observation and point. Hmmm. I was really hoping I solved your problem but I helped in no way. Sorry. Maybe someone else might have an explanation. Good luck.
This will sound strange, but sometimes an option will come up on the menu scope, as well as. Upper and lower line, and sometimes it doesn’t. Why I don’t know. For the longest time I could not get the compass and/or torque display to come up. But I kept trying intermittently over a few weeks and one day lo and behold, there it was. So far it has stayed. So my advice is keep trying.
It’s not a setting like that. You should not be in settings. Back completely out and then push up or down on the stalk to change functions. You will eventually get there. Additionally, if you go low, the MFD displays an alarm.
DR911s (07-01-2024)
