ID1300x injectors
ID1300x injectors
Currently have ASNU 850cc injectors on Magnus billet rails fed by -8 fuel line. I don't think that will be enough for my 4.0L 996T.
Thinking I'll get the ID1300x. Will they be a straight swap or will I need spacers of some description?
Will be going on with the engine in, but I don't have a secondary air pump so space will be easier.
The hats will need to be machined so the retaining clip will work. The ones that ID ground in are in the wrong spot.
simRen (07-01-2024)
They dropped straight into the factory fuel rail setup and installed like factory after that modification was made. I think people were using spacers in their fuel rails because they did not have this done.
simRen (07-01-2024)
Does this apply to the ID1000 injectors as well?
Are there any injectors that are 100% PnP?
That's twice I've seen you write IDC1300, I even followed the link you put in another post, but all I can see is ID1300x. Is there two different types?
Are all these injectors (ID1300x) the same or are they specific for vehicle? I've come across used ones from Evos,Wrx and Hellcats that look fairly priced but not sure if they would fit.
Would @CTS offer machining services to get these to fit just right? Or does someone know/have a machine shop that would do this.
I am probably going to use these injectors too since every tuner ive spoken too recommends these.
I say IDC1300 for brevity purposes but the one I use are the IDC1300x2. I think they may be even a newer / updated version now.
I took mine to a local automotive machine shop with the diagram and they had no problem knocking it out, it's a pretty easy job for any machinist. More difficult for the guys with a table vice and dremel calling themselves machinists
ok, so its USCAR female to mini timer male adapters i will also need to plug into my standard harness.
I think these are often called EV6 to EV1 as they usually appear on those bosch injector body styles. is it these ones?
