P2181 - Thermostat stuck open
I had my suspicions about the thermostat and my iCarsoft has now confirmed that I have a thermostat that is stuck open. Researching the change process, without removing the intake manifold and was just wondering can I avoid having to drain and fill the coolant? If I remove the water pump and thermostat how much coolant can I expect to lose?
theworkerbee (06-26-2024)
Perfect, thank you for confirming.
In terms of products, am I missing anything (this is my shopping list)?
30mm wrench to release tension on belt
Thermostat - https://www.design911.co.uk/p/thermo...--gts---turbo/
Intake socket - https://www.design911.co.uk/p/thermo...--gts---turbo/
Waterpump gasket - https://www.design911.co.uk/p/water-...anamera_2_2-2/
The special lubricant - https://www.design911.co.uk/parts/00004320593/
Am I missing anything?
Recently replaced my thermostat, at the 85K mi mark.
While removing the water pump a kitty litter pan was used to catch the coolant.
I replaced what was lost with fresh coolant. It took about 1 gallon at first, another quart was added after driving for a week.
The challenging part is removing the old thermostat. There are numerous YouTube videos detailing how it can be done.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_7848_2974f8e96fa44706b79c06a40a24cd2f3eac9a98.jpeg)
I was able to get in the tight space using these.
Also test your thermostats before installing to ensure they're working right. And loosen bolts before releasing the tension.
theworkerbee (06-27-2024)
