Hi I left my key in the 991 for a night, second day when I came back the battery is dead.
I tried several things. Purchased a CTEK - 40-206 MXS 5.0 and a cig plug.
But when I connect the charger to power and plug in cig, there's no indicator lights(does not mean charge does not work?). I also tried to open the car hood by connect positive and ground wire. I tried press the button on car or use the key fob, neither of them works.
Any suggestion here? Thanks!
you need to connect the CTEK cig plug to either the 12v socket in the passenger footwell or under the armrest. once it's connected right you will choose the mode (car logo).
you can't open the frunk by connecting a battery maintainer & if I'm not mistaken the black alligator clip is on plastic not metal so the circuit is not closed.
Thank you for the reply.
Tried both 12v socket in the passenger footwell or under the armrest neither worked. I think I need to get a jump starter.
I don't believe you can use a trickle charger on that connector in the fuse panel. The amperage is too low. You'll need an actual battery charger / engine starter OR portable jumper like shown below OR you could connect jumper cables to another nearby car battery.
Something like this...
or
You can see at about 2:45 in this video where the above device was used to do what you're trying to do.
or
Once you get it started, you might also want to take it to the dealer and figure out why the battery died. Assuming the battery is not too old leaving the key in the car overnight should not drain the battery. I have left my key in the car for six years when I’m not driving it- no issues.
did you use the red piece on the cig plug?
depending on the socket type, you may need that red cap on the cig plug, although some other sockets don't work with that cap, so try once with & once without.
But when I connect the charger to power and plug in cig, there's no indicator lights (does not mean charge does not work?).
That is the problem with the VAST MAJORITY of cheap battery chargers. Most of them do not work unless you have a MINIMUM battery voltage present. I know this from testing plenty of battery chargers in the lab I used to work in.
Also, battery chargers are not DC power supplies. To open the hood, you need a charged spare battery and some cables.
It is worth buying a quality battery charger/maintainer like a SOLAR PRO-LOGIX PL2320. I got mine on Amazon.
The part in the door jamb you have the black negative clamp on is plastic, not metal, isn't it? Hook it somewhere else - on a bolt or something. Even then tough sometimes to get the good ground.
For the reason why the battery drained so quickly, I think it's because I installed a carplay radio. The night when I was using my phone watching youtube videos I found my phone suddenly has no sound and it connected to the car's carplay... The funny thing is that I did not realize I keep the key in car that kept the radio active.
I finally managed to use the new jumper to open the frunk. Tried to connect the positive and ground wire to charge the battery, but based on the indication light of the charger, it does not work. Am I doing something wrong for the connection? Attached the pictures. Picture1 and picture 2 connection ways did not work. Picture 3 is the charger indication light.
I don't recall a mode where 3 lights are On. Try switching the mode using mode button to either car alone or AGM alone.
my experience with CTEK chargers is that they will show battery status once connected, otherwise red error light will be on.
in your photos the charger is connected to mains so it's On (green light) but it seem that it's still not "seeing" the battery for some reason.
