Looking to upgrade my turbo brakes
Anyone got an idea how to upgrade the 996 turbo brakes to look exactly like the gt2 pccb but with steel rotors?Basically more or less i just want the aesthetics because Ive done a gt2 front bumper and rear wing conversion and i want the caliper to be in the same position as the pccb ones, with the stock 997 turbo front and rear calipers but painted in yellow work fine? Do i need any sort of adapters? thanks
If you're going to use the stock 996 front/rear calipers with the 997 turbo 350mm brake rotors, then yes, you need adapters. There are several companies that sell them.
Then you need to buy 996 GT3 front calipers. You won't need spacers at that point for the front, but still will for the back as you'll reuse your stock 996 turbo calipers.
Go PCCBs... spendy, but awesome.
The following 2 users liked this post by BauerR:
blockhed (06-25-2024),
Ohio Performance (06-25-2024)
Why stop at 350 when you can do 380? These are for heavy lifting...
Those look at 2" thick...
1.5".....
Good for modulation of heat.
