Would you drive this car any further? (metal pcs in oil filter)
2001 986 2.7 with 150k miles, I've only had the car for 500 miles.
Before purschase, I had Porsche workshop do PPI during which they also changed oil filter (not oil), I cut it open by myself and saw small amount of metal flakes. That filter had been in the car for atleast 6k miles and for that mileage I thought it to be fine.
Yesterday, 500 miles later, I changed filter again and changed oil. See the cut filter below, biggest chunks are caught on picture, there were also smaller flakes easily seen by eye but couldn't get them to show on picture.
Since PO didn't know if or when IMS bearing was changed, I knew I was in for it's replacement + RMS + clutch set + flywheel + drive shafts.
Question is, would you dare to drive it another 1-2k miles to tackle all the jobs in winter.
Perhaps check with a magnet to see if they are ferrous (which could be IMS bearing) or aluminum (look aluminum to me) or non metal. Also, get a magnetic drain plug.
Received 1,854 Likes
If you want to know more on how to identify the different types of metal found in the filter or sump of an M96 engine, I encourage you to watch Jake Raby's "What in My Oil?" series. You have to be a Rennvision member to watch, but worth it.
The following 2 users liked this post by craigI:
Jerry Feather (06-18-2024),
tcora (06-18-2024)
Here are pictures of the filter from my 2000 base shortly after I bought it.
https://986forum.com/forums/boxster-...look-like.html
After another 10,000 KM the filter was cleaner if I remember correctly. So, IMHO, don't worry about the metal that you see. What I find more worrisome is if you have a lot of small dark brown plastic chips, indication that the cam chain tensioner pads are wearing. Again in my opinion, people should worry more about the cam chain tensioner pads and less about the IMSB.
IMHO, ignoring worn Variocam cam adjuster pads won't lead to catastrophic engine damage unlike a failing IMS bearing. You can monitor the health of the wear pads using a Durametric or similar scan tool, but aside from inspecting the filter and UOA, there is not much you can do to monitor the health of a IMS bearing. You have to take proactive steps to change it out like during clutch service.
Believing the myth that "if it (IMSB) hasn't failed by now, it will never fail", will only lead to disaster.
A blown engine would bankrupt the average 986.
Sorry to veer this off topic, but in a situation where the cam adjuster pads need to be changed, are there any "while you're in there" items to tackle?
If you do it with the engine out, like I do, you can verify the clutch, IMSB, RMS, AOS, replace all the vacuum lines and the vacuum reservoir etc. For the pads themselves you only have to remove the cam covers so I change o-rings on several parts... oil scavenge pumps, spark plug tubes, chain tensioners (referred to as adjusters in the Katalog) and a few others. You can change the timing chains between the camshafts also.
bcrdukes (06-30-2024)
Little update, the larger metal shavings seen on pictures were indeed non-ferrous, most likely aluminium. Magnet only picked up some very small bits which didn't seem too alarming. Thanks to all your inputs I figured - the engine needs to come out, there is just too much work to make sence any other way. I have large service pit + ceiling winch right above, which should make things easier.
For now, I guess I'll enjoy the ride till winter.
That's the ticket!
Again, I recommend running an engine oil with higher levels of molybdenum not found in the average Euro spec oil. Driven DT40 - LiquiMoly with Ceratec - MOTUL 8100 X-cess.
A bit off topic and getting ahead of myself, but idea being:
1) drive car over service pit
2) undo all accessories from engine
3) attach winch to engine and pick it up enough to relieve stress from engine mounts
4) undo mounts
5) lower engine + gearbox to the bottom of the pit (winch cable goes through car)
6) detach winch, roll car off the pit
7) winch engine back up from the pit
8) remove gearbox from engine
9) attach to engine stand
I might make a post about it how it turns out.
4) undo mounts
4) undo mounts
4) undo mounts
Good point, didn't realise that. Definitely doable the way you described or possibly support the car's rear jack points on 2 metal car dollies and move it that way.
