992 Turbo and Turbo S 2019-Current
Sponsored by: Porsche San Francisco
992 TTS trans fluid changing
Old 05-15-2024 | 06:52 PM
drmx1's Avatar
drmx1
Default 992 TTS trans fluid changing
Let's figure it out what fluids should be add for total trans maintenance:
Based on my searching in PET 8.2 and PCSS:
Trans PDK main
OEM #00004321044 4L
Drain plug #PAF009390 x2
Didn't see oil filter in this build
Front differential
OEM #00004330472 350ML (PCSS says)
Drain plug, not sure about PN#
Front transfer case
OEM #00004330563 700ML
+ flushing 1.7L (PCSS says)
Drain Plug, not sure about PN#
Rear differential
OEM #00004330472
didn't find capacity
Not sure about the drain plug, maybe PAF009389 ???
Please tell your experience and tricks.
Old 05-15-2024 | 07:18 PM
Angryinch's Avatar
Angryinch
You might need piwis3 for the transmission service…?
how many kilometres do you have on the car that your servicing this already?
Old 05-15-2024 | 07:23 PM
drmx1's Avatar
drmx1
sure I have the original piwis for servicing trans
I change all the fluids every 20,000 due to harsh driving
Old 05-15-2024 | 10:04 PM
Angryinch's Avatar
Angryinch
After a fluid change, does a clutch relearn need to be done? I’ll look it up.
please update this thread, good info here.
Old 05-16-2024 | 06:24 AM
drmx1's Avatar
drmx1
you can do trans relearn, but PCSS doesn't say you need it after changing ATF
Old 05-16-2024 | 01:46 PM
Crza81's Avatar
Crza81
Where can I purchase the Piwis? Thanks in advance
Old Yesterday | 01:45 PM
jangowow's Avatar
jangowow
Trans PDK main
OEM #00004321044 4L
Front differential
Front transfer case
Rear differential
OEM #00004330472
Did you figure out your issue?
From what I've found, rear diff (called pdk gear wheel set) is around 5L of oil.
Quick Reply: 992 TTS trans fluid changing
