992 TTS trans fluid changing
Let's figure it out what fluids should be add for total trans maintenance:
Based on my searching in PET 8.2 and PCSS:
Trans PDK main
OEM #00004321044 4L
Drain plug #PAF009390 x2
Didn't see oil filter in this build
Front differential
OEM #00004330472 350ML (PCSS says)
Drain plug, not sure about PN#
Front transfer case
OEM #00004330563 700ML
+ flushing 1.7L (PCSS says)
Drain Plug, not sure about PN#
Rear differential
OEM #00004330472
didn't find capacity
Not sure about the drain plug, maybe PAF009389 ???
Please tell your experience and tricks.
Trans PDK main
OEM #00004321044 4L
Front differential
Front transfer case
Rear differential
OEM #00004330472
You might need piwis3 for the transmission service…?
how many kilometres do you have on the car that your servicing this already?
After a fluid change, does a clutch relearn need to be done? I’ll look it up.
please update this thread, good info here.
