Engine Oil, Transaxle Oil and Transmission Fluid Changes
Sharing with the group the maintenance I do to my 991.1GT3 every other oil change (about every 2K miles I change oil). I drive my car 2-3 days a week and track it as often as I can. car has 51K miles. Some may think this is "too much" maintenance, but I enjoy it, it keeps fluids fresh, and I believe it will likely extend the life of my engine and transmission. I get my fluids from FCP Euro under their lifetime replacement program so it is cost efficient and environmentally sound :-) Enjoy....
Oil change (8 quarts of 0w40 Liqui Moly plus OEM oil filter)
Oil filter: 15 ft-lb, hand plus half turn
Oil Pan: 30 ft-lb
Oil Tank: 22 ft-lb
Final Drive Oil Change (3 liters Liqui Moly 75W90 Fully Synthetic Hypoid Gear Oil)
Drain and Refill PDK Transmission (~3 liters of Pentosin FFL-3)
- Remove engine guard
- Remove oil filler cap
- Remove 8mm hex from oil tank and drain
- Remove 8mm hex (stubby) front sump and drain
- Remove Oil filter and drain
- Install new filter
- Reinstall both drain plugs with new rings
- Fill oil with amount measured on drain (approx 7 quarts)
Oil Pan: 30 ft-lb
Oil Tank: 22 ft-lb
- Remove additional underbody cover
- Remove passenger side Fill plug (8mm) (3), Remove passenger side drain plugs (1) from diff and (2) from final drive
- Replace seal and tighten (1) diff drain to 10Nm
- Replace seal and tighten (2) final drive drain to 27 Nm
- Fill with LM 75W90 until drip
- Raise vehicle
- Start engine
- Engage 1st gear let it turn for two minutes
- Select Neutral AND WAIT FOR 10 MINUTES
- If oil runs out, its OK, if not add until it runs out
- REMOVE 150ml OF FLUID
- Replace seal and Install filler plug (3) to 27Nm
- Remove driver’s side Transmission fill plug (1) - you may have to move hoses out of the way - and drain plug (2) capture and measure fluid.
- Replace seal and tighten drain plug (2) to 15Nm
- Affix adhesive tape to the seam below fill plug to prevent spill seepage into oil pan
- Add Pentosin FFL-3 until it emerges from the fill hole, this should be close to what was drained.
- Replace seal and tighten fill plug to 27Nm.
- Replace hoses and remove adhesive tape.
- Replace additional underbody cover and tighten bolts to 2.7Nm
- Replace engine guard and tighten bolts to 10Nm
Very nice. Thanks
Are these same for 991.2 GT3 and GT3RS?
Every time. I have posted that on a separate thread:
https://rennlist.com/forums/991-gt3-...ts-thread.html
I think it is a different fill for these through a banjo bolt and washers. Not sure, hopefully someone with knowledge can chime in.
Fill port for .2 and GT3 RS... I think.
I use a hand pump for the Pentosin as it is a regular container. The gear oil has a built in extension tube that works well to fill from the container.
I have not seen an official Porsche "flush" routine nor service interval. I call what I am doing "drain and refill". I am doing this as a preventive measure but not to replace the full PDK service recommended at 96K miles.
