Transmission Mount Bushing Mod on 981
Pls share 'how to & tips' if you have mod the oem rubber bushings of the transmission mount to solid urethane or urethane insert
I had my indy install my WEVO semi-solid transmission mounts so I don't have any 'how-to' tips. However, I wrote about my impressions if you're interested in that:
https://rennlist.com/forums/981-foru...ts-review.html
Cayman Ed (05-01-2024)
Thanks for your feedback. Your experience in your 981CS is similar to my R53 MCS that I modded with solid urethane engine mounts, direct, raw, and it gave a feeling of more torque.
Would love to try this on my 981C.
What you linked to is the engine mount, not the transmission mount. (It's the trans mount on the 911). That seems like a huge pain to install, I don't see bring able to do it without pulling coolant hoses which means draining, filling, and bleeding the system.
Adding onto this, it's been recommended to start with adding stiffer transmission mounts before messing with the engine mounts. The reasoning behind this is that the transmission mounts are further from the cabin so there will be less increase in NVH vs stiffer engine mounts. The transmission mounts are also further from the axis of rotation of the car, so stiffening these would do more to reduce the "pendulum" effect of the drivetrain.
My bad if I put the wrong link but goal is really the transmission mounts. The WEVO used by Nam is a good option considering his positive review.
rennline makes some as well Porsche Boxster - Mounts (rennline.com)
I just replaced mine with OEM. I've gone down the rabbit hole with performance parts before. I prefer quiet.
I recently put the rennline mounts in my car. They were a tremendous pain to assemble, the performance is pretty good though and they were cheaper than new stock mounts. NVH-wise the softest insert option is about what I'd call the upper limit of acceptable. If this was purely a daily driver/fun weekend car I'd probably say not quite acceptable. I have to imagine it would be unbearable for anything but a dedicated track car with the stiffer inserts. I don't regret these mounts but if I had it to do over again I'd probably try filling the empty space in the stock mounts with window weld first.
They offer a softer "black" pillow option but even if I were to do it again I wouldn't feel the need to go softer:
https://www.wevo.com/Products/Chassi...-SSPillows.htm
Cayman Ed (05-02-2024)
