Manual GTS stage 1 (m-tune) vs turbo
Not really. Maybe if you had PDK and ran the E85 tune you might hang with a turbo but not stage 1 w/ manual. The turbo will murder you off the line and keep pulling on the high end.
This video shows a tuned 992 4S w/ diwnpioes and PDK and a 991.1 turbo S still pulls on it, though turbo s sounds like it has exhaust but no tune.
And what if the Turbo has a tune and exhaust? Bye bye 👋
The other limiting factor is going to be the stock manual clutch from what I can find. This is why they detune the Sport Classic vs the Turbo S. The PDK can take more power and torque.
I have an incoming manual 4 GTS and I went through the same mental math and just accepted that's its the fasted manual awd 911 that Porsche makes and left it at that.
has anyone pushed the manual that far yet?
There is no way in hell a manual is going to keep up with a turbo, tuned or not. Turbo does 0-60 in less than 3 seconds and is a low 10sec car in stock form.
“Power” wise on stage1 you’ll be in between a turbo and turbo S. But manual on the gts will make the turbo S gap wider especially on straight line.
What exactly are you looking to get out of your car?
If you want it for launches or you want to go fast in a straight line, Turbo/S.
If you want manual and RWD, GTS or SC are the only way.
If you want a lighter car, GTS will be at least 200 lbs lighter.
interesting! I was researching this as well and everything I had seen pointed to the clutch not being able to take much more power than the Sports Classic. But if there is 200 more ft lbs of reliable use then that’s awesome.
Also keep in mind that the factory PDK in the Turbos is an enhanced version over the factory PDK that comes in the base, T, S and GTS. Part of the reason for the Turbo S MSRP = $230k+ is the enhanced tranny I guess. Biggest issue with the standard PDK historically has been the electronic sensors inside the gear box mixing with hot gear oil = very, very expensive repair.
