ABS Sensor bolt...D'oh
So I finished the install of my new MCS 1-way coilovers. For some reason I was possessed to adjust the position of the ground wire as it didn't seem like there was much slack. While it was a bonehead move on my part the bolt must've been rusted enough that it wasn't even a degree of a turn and no pressure the head of the snapped right off. Does anyone know an alternative way of removing the rest of the bolt? Is it possible to keep the abs sensor plugged without the bolt and relocate the ground wire to a free screw on connected the body?
So far i've tried:
Kroil
Butane torch (had to be real careful b/c my cv boot is in close proximity)
screw extractor set
used a milwaukee cobalt drill bit to try and drill in hopes to clear it out and use a rivnut.
So far i've tried:
Kroil
screw extractor set
