Oil change
Oil change
Those of you that are doing your own oil changes, what oil are you using? I have done one oil change and dealer has done one. I'm about to do another one. I was told the oil in picture was the correct oil for 992. I figure this is more for European cars with the particulate filter and stricter emissions. Is this required for American Porsche?
I was just looking to do my first change after break-in, my owners manual said to use 0w-40 from Mobil 1.
Going to the Mobil 1 website and entering in my car, that oil is the only result. I was eyeing up 2 cases on Amazon as I type this.
Do you know the filter part numbers? Crush washer?
I was hoping to find an oil change kit online, but have been unsuccessful.
084runnerltd (04-28-2024)
this was the best deal I could find . . .
https://www.speedwaymotors.com/Mobil...ts,500571.html
I also change my own oil between each dealership service, and while it is probably a waste of money given how few miles I drive, it makes me feel better. It would be difficult to make a case that it's hurting anything but my wallet.
The spec is C40.
You need a special tool to remove the drain plug BTW.
The plug is replaced every oil change I think.
Add 9 bottles then check the level and it’s usually about a half bottle to fill it all the way to 3/4 full.
To reset the oil reminder and log the service you need piwis3.
The following 2 users liked this post by Angryinch:
084runnerltd (04-16-2024),
HOTCHKIS (04-16-2024)
In 2021 it was hard to find the X3 oil, had to get in from England the first two changes, then a PCA member told me our local Walmart had X3, I bought 10 6 packs, so I am good for few years
The spec is C40.
Apparently there is a special tool for removing the drain plug that gets changed every time, but I have been using a large flathead screwdriver bit with very little force and it has worked fine. Just don't over torque because you will probably crack the plastic drain plug. Not ideal though, and I should buy the tool if I can find an OEM one.
Yes a flat head should work too, it’s similar to their tool.
If anyone does oil samples we have a thread going to post it and compare.
The spec is C40.
I just did my first oil and filter change, the parts department at my Porsche dealership told me it would take 9 litres of oil to fill but my oil sensor is telling me to add another litre which I haven’t done due to the fear of overfilling and not trusting the sensor.
It sounds like you always put at least 9 and a half litres in without overfilling.
9 litres will def not be enough from what I’ve seen.
its more like 9 bottles and 35-40% of the 10th bottle.
992.Turbo.S (04-16-2024)
I will post this as I spent longer than I would like to admit trying to double check that I was buying the correct Mahle filter from Amazon.
I realize it can be found cheaper else where, but appreciate it coming with the plug and knowing it’s the correct filter.
Suncoast oil change kit
