235/40-19 and 285/35-19 Conti DWS 06 Plus on C4S
Will these sizes fit? I want to install Conti ExtremeContact DWS 06 Plus tires and keep the front/rear height ratio about the same. These are the closest sizes to the stock ratio, but they are taller than stock. Stock is 2.7% taller in rear. These are 1.9%. I know Porsche recommends 235/35-19 and 295/30-19 for winter tires and that’s a 2% difference. 0.1% difference seems close enough that the AWD system should be able to manage it.
Conti says that 285/35-19 is good for a 11” rim.
I wouldn’t mind a little extra sidewall height if they will fit. The fronts are 0.9” taller and the rears are 0.7” taller.
Thanks!
Thanks!
minuit997 (01-16-2024)
I have been looking at the Conti DWS 06 Plus as well for an all-season option as just don’t get enough snow to merit a dedicated winter tire/wheels. Was curious to hear your experience with the Conti’s?
Would also be nice to know the wheel size you are running, especially in the rear. I have Turbo wheels that are 11x19 in the back. I did read that 285/35/19 should be ok.
I have had really good experience with the DWS on my A6 as well so hoping the tires have worked out well for you.
Thanks for any update you can share!
I planned on doing this setup but my dealer accidentally ordered 235/35-19 instead of 235/40-19. So my winter setup is DWS 06+ on 235/35-19 and 285/30-19 on factory wheels in 19x8 and 19x11. I think they fit well! I’m very pleased with their grip and ride comfort. They’re much quieter than my PS4S summer setup.
From a circumference perspective, those are actually better than the 295/30 (2%) and 305/30 (2.87%) rears that most people run, but you do have less width on the rear from a traction perspective.
DWS06+ tires are superb. I run them on a BMW X5, Audi Q5, Infiniti FX45, and my son's 944 S2.
alaris (08-17-2024)
From: Bellevue, WA; '18 Macan S, '10 997S, SPASM, 6spd
I'm using the DWS06s (not plus?) on my C2S in 18" setup for the best ride. They are a bit soft and squishy, but the work great for my needs. Will work in any weather but the worst (where it'll stay in the garage). I put 235 in the front and 285 in the rear on -1 Porsche 18s.
I began the switch to all season tires a few years ago on my 1985 911, the Michelin A/S3+, and last year on my 2011 997.2, the Michelin A/S4. I was tired of them sitting in the garage for a few months each winter, and I’m delighted with the outcome. I don’t drive in snow, or with salt on the road. I’m not racing these vehicles, but I do drive them hard, and the tires are fine.
In fact, I find that my 1985 is better in the wintertime than summer , because the air conditioning is basically worthless in n the summer, whereas the heat is just fine in the winter. Mike
For what it's worth, if folks really want 19 inch all-seasons in the correct size (295/30/19 rear), I think only Toyo Proxes Sport A/S have both the front and rear correct sizes:
https://www.toyotires.com/product/proxes-sport-as
jtrecard (08-20-2024)
