Macan 2014-Current
Timing cover bolts failure
Old 10-31-2023, 02:57 PM
02m2
02m2's Avatar
Default Timing cover bolts failure
My 2018 GTS with 40k is showing some seeping on the passenger side upper timing cover bolts. I have checked around and this is apparently a systemic problem with the aluminum bolts. My dealer tells me not a factory recall yet and I have heard about the possibility of a class action lawsuit. I hear the fix is to use bolts from a 964 but the engine needs to get dropped.
Anyone have and further info?
Old 10-31-2023, 03:11 PM
Faust T.
Faust T.'s Avatar
check the thread pinned on top, it's a $400-600 repair if you just replace the bolts affected, not a permanent fix but it'll reduce the oil leak to minimum level.
02m2 (10-31-2023)
Old 10-31-2023, 10:31 PM
02m2
02m2's Avatar
what is the permanent fix?
Old 10-31-2023, 10:52 PM
wwahl
wwahl's Avatar
Drop the engine and do it right. Maybe $15,000. Porsche newer response. Replace two bolts. No engine drop. Cost is $750 Independent; $2,000 dealer.
Old 11-01-2023, 12:16 AM
AoxoMoxoA
AoxoMoxoA's Avatar
You forgot $37.95 DIY…
The following 2 users liked this post by AoxoMoxoA:
BobG999999 (12-07-2023), jsnavarro23 (11-28-2023)
Old 11-01-2023, 12:19 AM
wwahl
wwahl's Avatar
What is the torque requirement?
Old 11-01-2023, 12:28 AM
AoxoMoxoA
AoxoMoxoA's Avatar
Flat 6 Motorsports (who sells the 2-bolt kit) says 10nm for the torque, but good luck getting a torque wrench in there. Not gonna happen. I did the fix on mine and just snugged it up by hand with a short ¼” ratchet. Hasn’t leaked since.
Old 11-01-2023, 12:31 AM
wwahl
wwahl's Avatar
Sounds good.
Old 11-01-2023, 01:50 AM
02m2
02m2's Avatar
My independent porsche guy says he can take the “front off”
and do it for $1300. Called my dealer and they are going to look at it and see if they can get it cover under my now expired warranty.
otherwise I understand you need to drop the engine.
Old 11-01-2023, 08:13 AM
Zeus993
Zeus993's Avatar
Received 1,273 Likes on 586 Posts
I had mine done this last September by the dealership, under the extended warranty. I dodged a bullet with that one (extended warranty).
Old 11-01-2023, 10:31 AM
VAGfan
VAGfan's Avatar
You don't need to drop the engine to do a "full" timing cover reseal (remove the cover, replace the gaskets, replace ALL the bolts (about 30 of them !)).
The front bumper and radiators are removed, and then there is full access to the front of the engine to do this.
A good time to proactively replace the waterpump, thermostat, serpentine belt and idler and tensioner pulleys.
See Post #191
Cautionary Tale of Oil Leak (timing cover) - Page 13 - Rennlist - Porsche Discussion Forums
Old 11-01-2023, 11:43 AM
AlBinVA
AlBinVA's Avatar
Are the 2022 and up Macan's (specifically the GTS) susceptible to this issue?
Thanks
Old 11-01-2023, 12:39 PM
Faust T.
Faust T.'s Avatar
Thanks
no, only V6 models from 2015-2018,
Porsche switched to an AUDI engine form 2019 and the TCC leak is no longer an issue.
AlBinVA (11-01-2023)
Old 11-01-2023, 05:02 PM
DHL
DHL's Avatar
When I asked my dealer whether my 2022 GTS has an Audi engine, he replied it did not. So what is the real story about the 2022 GTS engines?
Old 11-01-2023, 05:28 PM
VAGfan
VAGfan's Avatar
The real story is that your dealer has no idea what he is talking about......
Penstamin (11-29-2023)
Quick Reply: Timing cover bolts failure
