GPS09 Pro Open in AiM w/ Accelerometers and Gyro
Rennlist Hoonigan
which cost no drachmas
This might only be exciting for the data geeks like me, but AiM just released RS3 3.63.20 which includes support of the GPS09C Pro Open being connected to an AiM logger and using the accelerometer and gyro in the GPS! This lets you to compare the g forces and gyro readings between the dash and GPS. It also gives you the same tech they use in Indycar and some other series. For folks who have a non-AiM system, you can use the GPS09C Open and Pro Open as a RS232 or CAN device to feed a MoTeC, Cosworth, Bosch, or other system. I've sold them from cars to motorcycles to boats and everyone is happy.
GPS09 C Pro Open accelerometer and gyro setup.
mlct (09-15-2023)
Rennlist Hoonigan
The GPS09 (of any version) is better than the GPS08. The GPS09 is 25 Hz data versus 10 Hz for all the old units. The GPS09 Pro Open while having the IMU, does not currently use it for dead reckoning.
Is the GPS09 Pro Open compatible with SmartyCam 3 Corsa as a standalone data logger?
Thank you for the offer, I do like to tinker so don't mind putting in the work to configure things... just requires Race Studio, correct?
Also about the GPS09c Pro Open, any concerns about signal strength at the base of the windshield? I have a 997.
Oh, and is the "Stick On w/ AiM CAN Harness (4m)" the correct one I should order from your site?
Rennlist Hoonigan
The front of the windshield should be good. The stick on is best if you don't want to drill a hole. This is the USB cable. https://trailbrake.com/open-usb-harness-5m/ Also, I have 4m and 2m AiM cables for the GPS, so just let me know which you want. I have to leave in about half an hour, so if you order after that it should go out tomorrow. We are getting 3-18" of heavy snow, so I'm not sure how UPS will be tomorrow.
Rennlist Hoonigan
I don't have anything extra. The ECULog should be shipping soon and all the details are out https://www.aim-sportline.com/us/pro...ulog/index.htm They both look very neat, but I don't have a date on the XLog. I'm getting my first GT32 wheel today.
