Lowered 992 picture thread
Old Dec 15, 2022 | 01:40 AM
Bekim911's Avatar
Bekim911
Registered User
Wink Lowered 992 picture thread
post some pics of your car lowered here is mine on H&R springs with 15 mm spacers in front and 12mm spacers in rear
Popular Reply
Dec 19, 2022, 12:55 PM
AlterZgo's Avatar
AlterZgo
Lowered from SPASM - 7/8” front and -1/2” rear on Bilstein EVO coil overs. Handling and ride quality in normal, sport and sport+ all improved over stock. Don’t get me wrong, even stock, the car never felt like it had great ride quality, but w/ Bilstein EVOs, it doesn’t feel like a lowered car as it seems to have pretty much the same suspension travel even when going over larger dips and bumps.
Old Dec 15, 2022 | 02:53 AM
por356's Avatar
por356
KW HAS
Old Dec 15, 2022 | 09:26 AM
tourenwagen's Avatar
tourenwagen
KW HAS kit
Old Dec 16, 2022 | 12:29 PM
Kram's Avatar
Kram
Would love an example of bilstein coilovers on a GTS with FAL and RAS. Is this a possible setup? Can't seem to get an answer. Thanks
Old Dec 16, 2022 | 04:55 PM
AlterZgo's Avatar
AlterZgo
I would assume that can be done b/c BIlstein EVO coilovers are available for the Turbo/S with and without FAL and I believe the GTS shares the same suspension as the Turbo so it should be fine. I'd reach out to @Staff@WORLD to see if they've installed these on a GTS since they've installed them on 992 Turbos and non-Turbos.
Old Dec 18, 2022 | 11:52 AM
Cst's Avatar
Cst
For all you guys who just lowered with springs......have you driven over 10k+miles on em yet? I'm interested in lowering my daily but not if the oem struts fail or wear out faster then a set of new tires ..
I'm assuming coilovers will last a lot longer ...?
Old Dec 19, 2022 | 12:38 AM
johnkent1212's Avatar
johnkent1212
For the guys with KW HAS how’s the ride compared to stock? I have a TTS and while I’d like to lower the car I’d like to maintain as close to stock ride feel as possible.
Old Dec 19, 2022 | 09:06 AM
aw305's Avatar
aw305
KW HAS kit
Old Dec 19, 2022 | 09:57 AM
johnkent1212
hows the ride compared to stock?
Originally Posted by aw305
KW HAS kit
Old Dec 19, 2022 | 11:25 AM
Bigoil's Avatar
Bigoil
Here is mine
Old Dec 19, 2022 | 11:26 AM
Bigoil's Avatar
Bigoil
Question for gents with lowered cars, do you know your camber specs?
Old Dec 19, 2022 | 11:52 AM
aw305's Avatar
aw305
if you were to take a ride in my car, you would not be able to tell the difference
Old Dec 19, 2022 | 12:54 PM
johnkent1212
good to hear. Do you change any of your camber?
Old Dec 19, 2022 | 12:55 PM
AlterZgo's Avatar
AlterZgo
Old Dec 19, 2022 | 01:36 PM
por356's Avatar
por356
First of all, beautiful car!
I feel that ride quality is compromised with the KW HAS kit, at least on my Base model. I had H&R Springs on my 964, and did not notice as big a difference in ride quality with it as I have with my 992.
Would I do it again? Yes, but most likely will look into the Bilstein EVO coil overs when and if the time comes.
BTW, wife and I are 76 yrs old, and she's never complained once about the ride quality.......she's a keeper for sure!
