964 Forum 1989-1994
What cured your Motronic error 21: Air flow sensor
Old Jan 26, 2021 | 09:07 AM
r-mm's Avatar
r-mm
Default What cured your Motronic error 21: Air flow sensor
Hi all
About once a month it seems I get a CEL and stumble on startup. It almost always clears with some throttle. Today it persisted and I read the code, attached. I believe this may be associated with my cold start issue, which remains an Unsolved Mystery.
Since my Alfa and 912 are taking all the garage space I need to strategize about this repair and curious to hear from any who solved it. I will follow the factory procedure attached and aware of the 'wiper track' issue and TSB on strain relief at the connector I believe common solutions require cleaning but not parts
Old May 17, 2022 | 08:25 PM
r-mm's Avatar
r-mm
Hey all I'm bumping my own thread here as this CEL code came back today when I got on the throttle this morning. Car was warmed up gently around town. Light appeared when I hammered on the gas on the on-ramp. Since I last posted I had the airflow meter on the bench and tested it against one Rob loaned me (said to be known-good). Both tested identically using procedures above. I cleaned the 4 pin connector on both sides and made sure the TSB ziptie thing had been done.
I do have a spare wiper track (from Alibaba) which I did not install as everything looked fine. Besides my cold start problem the car drives well.
Old Yesterday | 02:09 PM
dollar7499's Avatar
dollar7499
What fixed this?
Old Yesterday | 02:12 PM
r-mm's Avatar
r-mm
Great q, lemme ask my 2022 self. All I can say is I did eventually install the alibaba wiper track and since then everything has been ok.
Old Yesterday | 02:52 PM
dollar7499's Avatar
dollar7499
These threads are timeless as long as we're still working on stock machines I'll look into a replacement track and this thread improved thanks to you responding!
This might help someone in 2030!
Old Yesterday | 02:54 PM
r-mm's Avatar
r-mm
My other observation from many years of 964 ownership is that the connector is the source of the fault code a very muchness of the time. Knock sensor errors are 99% connector problems. My car looked basically good, no surface rust on fasteners etc but bear in mind every single engine bay electrical connection has zero moisture/humidity protection and they're all suspect. Hose it down with deoxit and clean every single groundpoint. I did this meticulously (not hard, no components need to be removed for access) and its paid massive dividends.
