Blew my 996
Blew my 996
Terrible day as my best friend failed on track at Mid-Ohio. I had just put Billy Boat mufflers, a ROW M030 suspension kit, Rennline Race Motor mounts, 997 shifter and a Rennline shift ****. I upgraded to an X51 baffle kit and was using 340 treadwear Continental Extreme Contact Sports, so I should've been okay. Key words there being should have. Now begins the process of rebuilding. I haven't split the block yet, but as you can see from the gold rush of an oil filter container something's been destroyed. Best guess from my friend's at P3 Autokrafte in Dayton is main bearings.
Now I turn to rennlist. I have rebuilt one engine two years ago in a shop class which was held in the middle of the night, so I'll call my experience null. My wrenching ability I would describe as average. I have bought the 996 service manual, and 101 projects for you 996. What else should I do, or get, or whom should I seek to help me try to rebuild this M96. As well as, should I explore boring or stroking while I'm in there. I'm planning on installing an LN engineering IMS bearing as well as an LN engineering .5 qt deep sump oil pan. I'm planning on getting a different car to be a dedicated track car, so I'll skip the 2 quart deep sump to avoid clearance issues.
Thanks in advance for your feedback guys!
So sorry to see this.
Yikes! Sorry for your loss but think of it as an opportunity to bump up the displacement to 3.6 or 3.8.
This long thread documents some major steps of my rebuild (3.6 to 3.8 LN nickies) may help https://rennlist.com/forums/996-foru...wn-engine.html
Ouch! I know that feels like a gut punch especially with all the money you've dumped into the car.
Not trying to add insult to injury or turn this into another oil thread, but what oil were you running? Did you lose pressure on the track?
Personally, if you wanted to rebuild the motor yourself, I would encourage you to take Jake Raby's M96 rebuild classes.
Bummer, this is why when I saw my oil pressure go down at Blackhawk on the long sweeper after 5 or 6 laps to 2-3 bar and then pop back up again once I got out of the turn I decided to call it a day. That doesn't change things for you though. Best of luck, rebuilding one of these engines is not the easiest or cheapest thing to do, especially with lack of experience.
Man, why don't you just put in a ticket with Flat 6 Innovations down in Georgia? In the long run, you will be better off with the engine they "reconstruct".
Cost prohibitive. I’m 22 and currently trying to get a house. If I rebuild myself I can do things as I get money in.
Jake told me if I could wait in line 12 mos and if 40k didnt scare me off (in a VM message) call him back.
Jake can be difficult. Good at what he doesnt but...
Needless to say I had another shop build my engine.
PS. At 22 I was racing a 2.0 914. Good on you.
I still can't afford a Porsche but I got one anyway!
Good luck and do keep us posted on your progress.
Sorry to see that. Good luck with your rebuild.
There are 2 questions you need ask yourself, to answer yourself:
1. Do you want to continue do track days with this car?
2. How much money do you have available to spend?
A reliable track engine is expensive, no way around it. From the looks of your canister, the crank is trashed. Your rebuild will require a new/good used one, likely best to start with a good used engine.
A reliable track engine will be $20k for a DIY effort with nickies, overbore, IMS Solution, head work, etc
To outsource, it only goes up from there.
