Does anyone have a recommendation for a 12-volt power adapter for a 2018 Macan base? The adapters that I have do not seem to meet the spec that is listed on page 104 of the Macan owner's manual. I've looked all over for an appropriate unit to no avail. Nothing I can find is 16mm or less from the center of the ground connection to the edge. That's pretty short...
I use a Belkin USB adapter in my Macan for my iPhone. I bet my measurement is 30mm and I have no problems with this charger. You can get one at Staples or probably at a Best Buy. Apple says using a brand name charger is important to protect the phone battery.
Reason: change picture size
I had no idea this could be an issue but I second the Aukey charger recommendation. That's what I used in my old car and shoved it right into the 2020 Macan console without thinking.
I have a couple of those aukeys but they're made of plastic and fell apart after a while. I purchased the Ainope 12v from Amazon and they're better quality / made of metal. One has two usb-a and the other usb-c & usb-a:
