12 Volt Adapter
12 Volt Adapter
Ladies and Gentlemen,
Does anyone have a recommendation for a 12-volt power adapter for a 2018 Macan base? The adapters that I have do not seem to meet the spec that is listed on page 104 of the Macan owner's manual. I've looked all over for an appropriate unit to no avail. Nothing I can find is 16mm or less from the center of the ground connection to the edge. That's pretty short...
Appreciate any ideas or suggestions.
from pg. 104 of the 2018 Macan owner's manual.
I use a Belkin USB adapter in my Macan for my iPhone. I bet my measurement is 30mm and I have no problems with this charger. You can get one at Staples or probably at a Best Buy. Apple says using a brand name charger is important to protect the phone battery.
I had no idea this could be an issue but I second the Aukey charger recommendation. That's what I used in my old car and shoved it right into the 2020 Macan console without thinking.
