Sponsored by: Road Spy
991 TTS fog lights?
Old 01-18-2019, 04:22 PM
mwlmd
mwlmd's Avatar
Default 991 TTS fog lights?
There is a fog light symbol to the left of the headlight switch. Is it functional?
Old 01-18-2019, 04:27 PM
Nanook
Nanook's Avatar
It illuminates a rear left tail light...it's a European thing
Old 01-18-2019, 04:39 PM
mwlmd
mwlmd's Avatar
How do you turn it on?
Old 01-18-2019, 04:59 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,248 Likes on 783 Posts
Pull it, as I recall.
Old 01-18-2019, 05:18 PM
mwlmd
mwlmd's Avatar
Thank you!.. Will give that a try.
Old 01-21-2019, 07:26 PM
Need4S
Need4S's Avatar
As I recall, you have to turn the headlight switch to full on (all the way to the right) in order to pull on the fog light switch. It won't pull out when set on "auto".
Old 01-22-2019, 02:35 AM
mwlmd
mwlmd's Avatar
Yes exactly. I was trying to pull it in auto with no luck.
Thanks.
Old 01-22-2019, 02:21 PM
sscofield
sscofield's Avatar
All correct....but be careful. It is a European “thing” as a fog light. In the US, it will look like a car with a tail-light out on one side, and attract attention from the authorities.
Old 01-23-2019, 12:16 PM
mwlmd
mwlmd's Avatar
I don't think I will actually use them. I was mostly curious to know if they were functional.
Old 01-23-2019, 01:22 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Sorry I forgot to mention that it wouldn't work in auto mode!
I use my fog lights regularly. I live in the mountains, and we see significant fog fairly often. I see quite a few other cars using their fog lights too (including rear fog lights), so I'm not the only one out there!
Old 01-27-2019, 12:30 PM
chance6
chance6's Avatar
Received 1,480 Likes on 951 Posts
It's a nice feature in bad weather, it illuminates the driver's lane from the back so you can see in the side mirror.
Old 01-27-2019, 12:41 PM
Pmorritt
Pmorritt's Avatar
i cant find it now, but i believe when you activate the rear Fog light function on the 991, it changes the front headlight beam pattern to see better in fog conditions.
Found it. With the rear fog light on & at speeds below 43mph the headlight beams become wider to reduce glare (pretty smart)!
Old 01-27-2019, 04:18 PM
mwlmd
mwlmd's Avatar
Very cool!
Quick Reply: 991 TTS fog lights?
